Old 10-29-2008, 06:04 PM   #11 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Jordan_Nave -
Originally Posted by Jordan_Nave View Post
I usually put my car into Neutral and this lowers the engine idle speed. Does this reduce gas consumption or am I just a nut?
Probably not much. If you are on the flat, the line is straight, and the car weighs less than 2500 lbs, you could open the door and push it with your feet. The best situation is a slight incline and let gravity do the work.
CarloSW2
American Solar Energy Society
Old 10-29-2008, 10:01 PM   #12 (permalink)
Jordan_Nave's Avatar
1996 Sable LS - '96 Mercury Sable LS
90 day: 27 mpg (US)
1997 Mercury Mountaineer - '97 Mercury Mountaineer
90 day: 16.96 mpg (US)
Originally Posted by cfg83 View Post
Jordan_Nave -
CarloSW2
That is what I figured
Old 10-29-2008, 10:59 PM   #13 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Once I get the CitiCar really running right, I MUST take it through a drive-thru, just for the laughs!
(And no gasoline use, did I mention that? Cuz, you know, it's electric. Doesn't use gasoline, in a drive-thru or anywhere else. And it's funny looking.)
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-30-2008, 01:12 AM   #14 (permalink)
* Unless you drive naked. In that case, stay in the drive through, please!
i dont know, some females could pull it off.
In hot weather, that is a perfectly valid hypermiling tactic. Then you don't have to use the A/C as much and reduce the Lenz's drag by reducing the current drawn... Of course, it's for truly dedicated hypermilers only...
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 11-05-2008, 01:44 AM   #15 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
http://articles.latimes.com/2007/oct...n/ed-methane15
Old 11-05-2008, 11:22 PM   #16 (permalink)
Originally Posted by Wonderboy View Post
Keep in mind the basic CHEM 107 knowledge - in other words, the carbon released from the animals originally was captured by the plants they eat. The only non-carbon-neutral part would be the use of fossil fuels in processing, manufacturing fertilizer, etc. Organic meat should be more carbon-neutral as they don't use synthetic chemicals.
Soy is a much better source of protein as far as the environment is concerned, though. And the quality of that protein is pretty competitive with that of animal protein. Not to mention that the reduced fat content would avoid the unwanted weight gain that would spoil your looks (especially for those going for the "celebrity skinny" look) and reduce gas mileage. (Yes, I'm serious about the part about reducing gas mileage. Extra weight needs more energy to accelerate.)
Old 11-06-2008, 04:22 AM   #17 (permalink)
Wonderboy's Avatar
Not to discount your reference to chem 107, as I honestly didn't have that in mind (thank you for bringing that up), but I've just always thought and knew that there is nothing carbon neutral about producing corn and feeding it to cows. The fossil fuel and chemicals wasted in the production of beef (and dairy products for that matter) would be the only thing up for "violation" of non-carbon neutrality. Not to mention all that water. I could go on, but I did realize this was slightly off topic, so my link was intended simply to allude to the fact that yes, of course the answer to saving gas at a drive-thru is not using it at all, but the whole idea of going to any fast food joint defeats the purpose of saving gas/resources and helping to "green the planet". Yes meat and cheese are delicious, no they are not "green". Some people may be here to save gas AND conserve as many resources as possible, others may be here exclusively to push their mileage to the limit. Both reasons have merit, I just think it's important to consider reason #1 if you hadn't. I've only recently gotten behind reason #1 myself. It seems to me that trying to save gas at a drive thru while the things you buy there will cost more gas than you will save in your life at drive thrus is reasonably superficial.
That's just what I think...
Old 11-10-2008, 01:50 PM   #18 (permalink)
Except that I may want that beef topped with cheese, but no rational person "wants" to waste gas. There can be a reasonable compromise between being nice to the environment (which should only be done to serve humanity) and doing those things we enjoy that might not be the most ecofriendly.
I'd say meat consumption is reasonable; a 2 ton truck with open windows and a gun rack going 95 isn't.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Lower idle RPMs save gas? Xringer EcoModding Central 5 06-14-2008 10:19 PM
