01-25-2011, 07:54 PM
#11 (permalink)
home of the odd vehicles
Honestly the SGII is exactly what it needs to be, the only real improvement that would make me pull the trigger on a SGIII is full diesel compatibility with gasoline like accuracy.
01-25-2011, 07:58 PM
#12 (permalink)
Pokémoderator
rmay635703 -
How about an SD-Card or USB port that allows for datalogging? A comma-delimited text file is all you need to go spreadsheet crazy.
CarloSW2
01-25-2011, 09:12 PM
#13 (permalink)
Originally Posted by cfg83
rmay635703 -
CarloSW2
If it would enable me to gradually map out the engine acceleration efficiency so I could have a more suitable method of accelerating that would be a plus but it better come with a good proggy to do that.
As far as I know there is no engine map for the 2.2 Ecotech I've seen.
01-25-2011, 09:43 PM
#14 (permalink)
...beats walking...
+1 on the USB port for enroute data logging!
...an engine map of our Ecotec 1.4LT engine would be nice
01-25-2011, 10:26 PM
#15 (permalink)
And +2 on datalogging capability with a removable chip. A usb memory stick would be nice but would likely be cumbersome and bulky, SD or similar would probably be a better option.
Doug
01-25-2011, 10:27 PM
#16 (permalink)
My scangauge 2 is pretty accurate, within .5 gallon on fill ups.
I figure some error is in the 8 oz of additives I add, and there has to be some error in refilling, you're not going to get exactly the same in there all the time.
What kinda of accuracy you seeing with gas cars?
01-26-2011, 05:34 AM
#17 (permalink)
aero guerrilla
Yes! Yes! Keep it coming before I wake up!
01-26-2011, 08:15 PM
#18 (permalink)
Odd my gas cars are about that accurate but the diesel varied by +/- 40% and never would center.
01-28-2011, 10:08 AM
#19 (permalink)
Have you tried using only 3/4 of the actual displacement and only correcting halfway towards the actual values ?
On my diesel it's getting very near the actual numbers - except when I'm P&G-ing.
01-29-2011, 05:42 PM
#20 (permalink)
Engineering first
I'm hoping to see: - memory card XGAUGE programming - so we don't have to do everything in the car
- memory card recording - so we can get history of "n" data elements with time-stamps
- handling multiple data items in the same response - so I can use both MG1 torque and rpm to know the actual ICE power at any give time
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
