Old 04-25-2013, 03:28 PM   #461 (permalink)
The lower picture look pretty close to what I have in aluminum.
Old 04-26-2013, 09:49 PM   #462 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
^ hey thats my Yaris!
I used to have an xB...if i kept it instead of trading it in for the Yaris, I would have swapped the trans out for an Echo unit (Yaris trans case is different then xB/xA/echo) with the taller final drive. Best tank ever was like 39mpg. Now I get at least mid 40s beating the crap out of my Yaris & low-mid 50s when "trying". Gearing & aero definetly makes a hooge difference. Same exact motor.
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 04-29-2013, 09:50 AM   #463 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by malibuguy View Post
I used to have an xB. Best tank ever was like 39mpg. Now I get at least mid 40s beating the crap out of my Yaris & low-mid 50s when "trying". Gearing & aero definetly makes a hooge difference. Same exact motor.
Is the Yaris lighter too? Interesting but not really surprising. Thanks for posting your real world experience.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 05-01-2013, 11:40 AM   #464 (permalink)
MPG...what?
they are i believe withing like 20lbs of each other.
-10 Yaris sedan
-96 Tercel
Old 05-01-2013, 03:41 PM   #465 (permalink)
Land Shark - '11 Toyota Yaris 3dr Hatchback
90 day: 36.68 mpg (US)
Does the Yaris Sedan have a different radiator or is the radiator position than the hatchback? On my Yaris that grill block would direct very little air into the radiator and a lot between the factory belly pan and the transmission/engine. That's because the radiator goes from about middle of the top grill to middle of the bottom, and it's only about 2/3 the width of the grill openings and off center to the driver's side. I've been experimenting with grill blocks in cardboard before I move to coroplast. I'm still not happy with the temps though, with an unblocked grill it used to sit at 185, sometimes going to 186.5 when accelerating and peaking at 190.2 when initially stopped. With my current grill blocks it sits at 186.5/188, going to 190.2/192 when accelerating and sometimes as high as 195 when initially stopped, and it's still cool out but summer is coming and temps will rise.
Old 05-01-2013, 05:45 PM   #466 (permalink)
Sean,
You should probably block off the opening in the "chin" area, between the spoiler and the base of the radiator. Then, all of the air that enters the (partially blocked) grill will go through the radiator. This will helps the temps stay below the 204F when the fan comes on, and you can get by with a small opening - mine is about 4.5" x 15" in the lower opening only. The entire upper grill is blocked, and my temps are fine.
Old 05-12-2013, 11:02 PM   #467 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Good read.
The Following User Says Thank You to mikeyjd For This Useful Post:
NeilBlanchard (05-13-2013)
Old 06-24-2013, 04:37 PM   #468 (permalink)
Newbee Hypermiler!
harshalsk's Avatar
SilverHondaFit - '13 Honda Fit
90 day: 35.72 mpg (US)
My dream to beat Neil's FE records shattered on 6/17 when I had an accident on I-35 and my beloved Scion xA was totalled.
It was the most fun car I ever enjoyed. sob!
Neil, take care of your Scion and drive safely.
Newbee Hypermiler!
Old 06-24-2013, 08:29 PM   #469 (permalink)
Sorry to hear this - are you okay?
Old 06-26-2013, 06:50 PM   #470 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Neil, I remembered the scissor tape you had applied on your A pillars when i saw these scissor shaped sections on the Rafale jet fighter.
Did you ever notice a difference with the tape ?
Ex : Did raindrops behave differently on the side glass
grille block
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 08:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 03:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 06:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 06:44 PM
