01-26-2012, 05:48 AM
#11 (permalink)
needs more cowbell
yah, and even electric vehicles can benefit from having actual gears to choose from downstream of the motor, i.e. so you can climb hills AND go 70mph.
The Following User Says Thank You to dcb For This Useful Post:
01-26-2012, 09:01 AM
#12 (permalink)
They are beginning to figure that out dcb.
regards
Mech
01-26-2012, 05:06 PM
#13 (permalink)
It takes a transmission specifically designed for electric motors. Regular car transmissions cannot handle the instant torque -- ask the good folks who built the Illuminati '7'. Even the differential was destroyed by the electric motor.
And Tesla tried a 2-speed transmission, and then discarded it. Direct drive is better, and more efficient.
01-26-2012, 05:56 PM
#14 (permalink)
I got alot going on right now , so im going to have to just quit my planning , researching , and deciding. Too much stuff on my mind right now so need to put all this on hold.
But from everything trying to decide in my head without being able to really sit down and think it through cause of stuff that always comes up and has come up now.
I think im going to go to the ICE setup and just do the best I can with mpg with the performance im looking for. Alot of reasons which I havent fully sit down and figured out pros and cons and how accurate my reasons are but cant right now. But think im going that way.
01-26-2012, 06:46 PM
#15 (permalink)
Electric motors have efficiency curves like ICE's do; and if the vehicle has wide enough variations in environmental demands placed on it (low neighborhood speeds AND turnpike speeds; steep hills and flats; empty and heavy loads) an EV with gears has a definite leg up.
As far as "regular" transmissions being too weak, well, that was just a poor choice of transmissions on the part of the builder(s). If people build 1000 hp street machines with transmissions, you can sure build an EV with one.
As far as the Fiero, you can expect 90+% efficiency with a stock a/t and, oh, 94+% efficiency with an m/t. ICE>generator>motor would certainly be far worse.
01-26-2012, 07:53 PM
#16 (permalink)
He will figure it out eventually Frank. Direct drive EVs need motors that are too large and they can't regenerate 30% of any decelerative energy, without some way to raise the motors RPM.
A 60-0 panic stop only takes about 20-25 revolutions of the wheels, he can't explain how you are going to pack 600 HP seconds of energy into a chemical battery in 25 revolutions of an electric motor generator unless its as big as a power plant, and the battery weighs several tons. He will avoid the point by saying you should never have to panic stop.
regards
Mech
01-26-2012, 08:01 PM
#17 (permalink)
Might actually learn something if he read the link. Even EVs can benefit from capacitive load levelling with a capacitor or accumulator. but it won't happen with direct drive which still requires a differential or two motors.
Electric Hydrid
regards
Mech
01-26-2012, 08:10 PM
#18 (permalink)
01-26-2012, 08:12 PM
#19 (permalink)
things have calmed down for the moment so I have time , especially since its dark out. I cant go outside and get things done and etc...
I have decided to just go the route of a full ICE setup , 1-2L displacement because I can get enough N/A power out of that sized displacement and gear towards what I need for what I want. While keeping the reduced weight im looking for.
170+ HP from 1L minimum, but peaky and narrow powerband so not much down low but quick revving if geared enough to not struggle to make up for it. tuned where peak power occurs at a healthy and reliable mean piston speed. I dont know what efficiency would end up being with this because I would still be able to cruise with low HP but in lower rpms with an engine which favors higher rpm.
came concept as formula one to where it should perform well still?
01-26-2012, 08:15 PM
#20 (permalink)
Motorcycle engine? Lots of shifting but if the power is there it should move. Possibly somewhat more efficient than a stock Fiero, but possibly not.
