Old 01-07-2019, 10:28 AM   #111 (permalink)
Could you modify the housing to allow a second, larger filter?
Too small.
Probably have to change the housing to fit something bigger, but it's a tight fit behind the glovebox.
Apparently it's also an issue on other small hatchbacks here (that you don't get Stateside)
The Following User Says Thank You to niky For This Useful Post:
Xist (01-07-2019)
Old 01-07-2019, 11:57 AM   #112 (permalink)
How about a chunk of poly(something) foam on the outside over the air intake as a pre filter?
Old 01-07-2019, 12:40 PM   #113 (permalink)
90 day: 29.78 mpg (US)
What about removing the filter? My body already has a filter called mucus membranes.
...or is the fitler to keep the fans and levers from gunking up with dust?
Old 01-07-2019, 12:44 PM   #114 (permalink)
I don't own anything that has a filter.
aerohead (01-16-2019)
Old 01-07-2019, 12:57 PM   #115 (permalink)
You don't have a filter!
The Following 3 Users Say Thank You to Xist For This Useful Post:
Fat Charlie (01-16-2019), MetroMPG (01-07-2019), niky (01-07-2019)
Old 01-07-2019, 01:28 PM   #116 (permalink)
Is it noticeable?
The Following 4 Users Say Thank You to Frank Lee For This Useful Post:
aerohead (01-16-2019), Fat Charlie (01-16-2019), niky (01-07-2019), Xist (01-07-2019)
Old 01-07-2019, 02:03 PM   #117 (permalink)
Sweet! All optioned out and everything. Ivory knobs and chrome handles.
Clock and radio, gas gauge, bamboo shelf and [batwing] steering wheel wrap, defroster vent helpers, and an actual pedal on the throttle roller. It even has a right-hand sun visor!
I got a ride in a VW Jetta. The right-hand sun visor had a lighted mirror with a switch to turn it on and off. The switch had a plastic component that was broken so it took two hands to store the visor. I told him about the green see-through visor in my (two) oval window Beetles.
Times change.
(That right-hand door pillar is missing a plug over one hinge bolt, the door check strap is missing and the domelight switch is a blanking plate. I don't recall if they had a passenger door courtesy light.)
Old 01-07-2019, 09:16 PM   #118 (permalink)
It's the cabin filter, not the air intake. And if you're talking about the outside air vents, given the pollution in this country, 99.999% of the time, the system is on full recirculation, windows up.
I think that's the ticket.
Which reminds me... I really should clean it and put it back in. Haven't driven the car regularly for a few weeks (doing an evaluation on a truck, with free diesel, so...), and I keep forgetting.
Old 01-07-2019, 11:35 PM   #119 (permalink)
Most people here use the recirculation only too, not due to pollution-related concerns. I'm sure some use it as an excuse to not replace the cabin filter...
Old 01-08-2019, 10:14 AM   #120 (permalink)
90 day: 51.82 mpg (US)
I've always thought of cabin air filters as another kind of razor blade refill for cars.
Needless to say, I've never had a car that came with one either.
