05-01-2010, 12:54 PM
#11 (permalink)
Most modern autos beat manuals for FE these days.
05-01-2010, 07:54 PM
#12 (permalink)
Pishtaco
Originally Posted by ShadeTreeMech
Something I've always wondered about is why couldn't a manual clutch be fitted to an automatic transmission? You'd have to use the clutch as in a manual car, but the shifts would be automatic and you could take advantage of the better ratios. What energy losses are there in the auto other than having to pump the fluid?
Actually, you want it the other way, a manual transmission with an automatic clutch. People who can't/won't use a clutch, don't, and they're not about to learn. Lots of people don't mind shifting, however. Rambler offered that combination with its e-stick 50 years ago. The Ford tranny Nevyn describes sounds like it may be the ticket.
There's no advantage to your suggestion, AFAIK. It's simple to swap gear ratios in a manual transmission, and people who won't/can't use a clutch, won't.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
05-01-2010, 07:55 PM
#13 (permalink)
EtOH
Originally Posted by Nevyn
That's what the Ford PowerShift 6 speed automatic is. It's an electronically clutched and shifted 6 speed dual-clutch manual gearbox. No Torque Converter, no ATF - just gears.
Uh, no on the manual part. The DCT can hold top gear but other than that the gears are automatically changed. And the clutch doesn't have a foot pedal. It's an automatic and even if it was sequential it would be a manual transmission in anyway. It uses a dry clutch so there's no more advantage for towing capacity anymore.
Some of the drag racers with big HP engines use 2 speed powerglides(an automatic) and they convert them to manual shift. Other than that there's no way to mix the two without building an entirely new transmission. I'd take a 6 speed manual with a 3rd pedal over the DCT.
-Allch Chcar
05-02-2010, 04:09 PM
#14 (permalink)
J KP, guys. J KP.
@wagmore: Remember that your 15-year-old Passat ( this one?) was rated using the old EPA cycle. The revised "official" numbers are 18 city/27 highway, which is actually worse than the 2010 Passat.
(For my money, the EPA numbers no doubt have flaws in them, but even though they're far from perfect, at least they allow us to compare wax apples to wax apples.)
05-02-2010, 05:10 PM
#15 (permalink)
My Jetta TDI has a auto DSG gearbox, with gears and 2 clutches, all computer controlled. Fantastic MPG. A manual could not possibly be better.
05-02-2010, 05:30 PM
#16 (permalink)
needs more cowbell
not possible?!? Are you serious? even the epa site lists the manual wtdi jetta ith a higher mpg than the auto.
Look, Manual is simpler/less expensive/less weight/more efficient/easier to get it to do what you want/more reliable.
Manual is the standard. Auto will always be trying to catch up, at great expense, stupid idea from an efficiency perspective.
05-02-2010, 05:31 PM
#17 (permalink)
needs more cowbell
Not in the models designed for efficiency.
05-02-2010, 05:36 PM
#18 (permalink)
Basjoos Wannabe
an automatic clutch would be great. Especially if it were a torque convertor with an eager lockup. Slipping the clutch in low traction situations is the only disadvantage I can think of with a manual, and a torque convertor would cure that in a hurry.
RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
05-03-2010, 09:29 AM
#19 (permalink)
38 time NHRA/IHRA Champ
I noticed that our 05 Scion Xb that we used to own with tyhe automatic was rated 35 mpg...and got it, while the 5 speed sticks were rated at 34....BUT hypermiling would be easy on the stick!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
05-03-2010, 12:32 PM
#20 (permalink)
External combustion would mean no gearbox whatsoever, you won't beat that with a manual or an auto.
Work From Home mod has saved more fuel than everything else put together.
