Old 02-16-2010, 10:17 PM   #31 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Wow! Frank kicks s*** up and it stinks. May wonders never cease?
(Frank, that was wide open, how could I resist?)
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 02-16-2010, 10:49 PM   #32 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
LOL Chaz... I see you're another social pessimist, not unlike myself!
Old 06-15-2010, 01:20 PM   #33 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Several months back, Automotive Engineering had this picture of a Porsche Carrera.
It shows the air flow through the wheel well, similar to what AeroCivic has mentioned in his design.
In the same magazine was shown a picture of the VW Up!
Jim.
ID:	6185   Click image for larger version
The Following 3 Users Say Thank You to 3-Wheeler For This Useful Post:
aerohead (06-19-2010), Christ (06-15-2010), landsailor (08-28-2011)
Old 07-12-2010, 01:59 PM   #34 (permalink)
3-Wheeler's Avatar
This is a picture of CFD analysis for the Chevy Volt.
The article went on to say that nowadays, the preferred method of measuring air drag is with CFD.
Building a clay model with the same level of detail that can be achieved with the CFD is cost prohibitive, and the CFD gives the results in a reasonable time period.
The grill was detailed in such a way as to meet the cooling requirements on the hottest day in Arizona for example.
Jim.
ID:	6336   Click image for larger version
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
aerohead (07-13-2010), KamperBob (07-12-2010)
Old 07-12-2010, 02:38 PM   #35 (permalink)
...beats walking...
...looks like the "back-end" of the VOLT could definetly use more aero work!
Old 07-12-2010, 09:00 PM   #36 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Probably. Then again, when we only get to see data from the symmetry plane that offers us limited understanding of the 3D wake and overall drag of the vehicle. The head-on dispersion lines are helpful. Seeing the same from the rear would be really nice.
Cheers
KB
Old 07-13-2010, 09:03 AM   #37 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Yeah. Did you see the video of the Volt engineer bragging about how great the aero was and that the 1/2" lip "spoiler" on the back added 1/4 mpg? BWAHAHAHA!
Old 07-13-2010, 05:23 PM   #38 (permalink)
back-end
A neighbor is planning to buy a VOLT.At some point we can run my trailer behind it to look for a difference.He's a pilot and a good friend of his is an ultralite designer so he's kinda 'gets it.'
Should be fun! West Texas is installing an enormous amount of windpower generating capacity on top of what it's already done.We have a shot at zero-carbon commuting staring us in the face.Not quite Santo Island,Denmark,but way out ahead of nothing.
Old 09-23-2010, 01:30 PM   #39 (permalink)
3-Wheeler's Avatar
Here are several pictures of the Nissan Leaf.
The first picture shows just how small this car really is.
The second picture shows the adjustable inlet for cooling, presumably partially for controlling electric motor temperatures. I would imagine this inlet is computer controlled by the main computer.
Jim.
ID:	6908   Click image for larger version
The Following User Says Thank You to 3-Wheeler For This Useful Post:
aerohead (11-20-2010)
Old 09-23-2010, 01:56 PM   #40 (permalink)
If GM's cfd lofting is so great, why does the Volt have such sucky drag in this day and age?
I always look at the front corners of the vehicle, where air flow is fastest and therefore drag per square inch is greatest of anyplace on the vehicle. If there are lumps & bumps or nooks & crannies there (as Volt has), it tells me the designers are pikers.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Group Purchase of Aerodynamic Modeling Program windrider919 Aerodynamics 16 09-10-2009 07:02 PM
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
