Old 08-31-2008, 06:12 PM   #131 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Well I order my stuff to make my MpGuino tonight, Can't Wait.
Old 08-31-2008, 08:13 PM   #132 (permalink)
Addicted
bbjsw10's Avatar
Originally Posted by bbjsw10 View Post
I have started accelerating differently, I was taking off at 10in. hg. now I have began to take on in first shift to second at like 5 mph, and 2nd-4th about 4-5in. hg.
I do not believe this worked for me, mileage drop of 10mpg. I would expect some difference but not that much. Back to my 10in. hg. takeoffs.
Old 08-31-2008, 08:16 PM   #133 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
The 3 cylinder Suzuki engine mostly works in the power side during normal driving, but when you keep vacuum at 10 or higher, you are getting the best economy.
GeoMetroforum.com - got mpg?
Old 08-31-2008, 08:35 PM   #134 (permalink)
Addicted
bbjsw10's Avatar
Went back and checked my fuel log and the first tank with vacuum at 10, I am sticking at 10. That is until I get MpGuino, I just hope I have it together before the Ohio/PA meet on the 14th.
Old 08-31-2008, 10:40 PM   #135 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
You'll probably have your Guino built before I get back from my trip to finish calibrating mine. Maybe you'll be able to share some of the finer tips.
Old 09-01-2008, 12:46 PM   #136 (permalink)
Addicted
bbjsw10's Avatar
I hope to have pretty soon I did the upgraded shipping. When I get the stuff I will be like a mad scientist until finished. I will definitely share any info I come up with.
Button cover idea I had.
Old 09-05-2008, 10:47 PM   #137 (permalink)
Hi-Tech Redneck
Go to your UserCP and paste this code into "Edit Signature" and let me know what you think.
PHP Code:
[CENTER][URL="http://ecomodder.com/forum/showthread.php/starting-mod-my-xfi-3887.html"][IMG]http://i75.photobucket.com/albums/i315/planetetf/XFisig.png[/IMG][/URL][/CENTER]
Old 09-19-2008, 11:02 PM   #138 (permalink)
Addicted
bbjsw10's Avatar
Thanks for new sig Johnny!!
I got my MpGuino all built and tested tonight!!
dcb is the Master! All I need to do is mount into a case now. I had a case made but ended up slightly too small now I have to go looking in the morning for something to use. And I am changing the type of buttons I had. Can't wait feel like a kid at Christmas. Gotta go to bed so morning gets here faster. I will post pics when done.
And I still have to clean car the rest of the way from the Meet of Johnny's. Went great by the way will be there for next one for sure.
Old 09-20-2008, 04:46 PM   #139 (permalink)
Addicted
bbjsw10's Avatar
My MpGuino
I figured out my alternator kill is causing it to reset, from the initial voltage drop when shutting off.
The injector kill switch causes it to lock up as well, so I am going to use dcb's recommendation for using the cam pickup wire to kill engine for EOC. No biggie just some solder and heatshrink to fix it. Tomorrow, tomorrow it's only a day away.
Old 04-14-2009, 01:41 AM   #140 (permalink)
Puerto Rican Hypermiler
jomelmaldonado's Avatar
Toyota Echo - '05 Toyota Echo
90 day: 41.71 mpg (US)
Hi Bob, what did you used to cover the wheels so neatly. I've been brainstorming ideas of materials, but haven't found anything yet.
Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed MetroMPG EcoModding Central 31 11-09-2014 05:28 PM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
How to tell an XFi from a garden variety Metro MetroMPG General Efficiency Discussion 6 07-12-2008 10:48 PM
XFi vs. LSi? NoCO2 General Efficiency Discussion 3 06-03-2008 09:48 AM
Quick and easy licence plate aerodynamic mod :D blackjackel Aerodynamics 7 05-13-2008 07:20 AM
