Old 04-29-2010, 06:59 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Aero Apprentice
swede's Avatar
Swede's AeroLid build thread
Following in the footsteps of others here I have decided to build an aerodynamic cover for my 2009 GMC Sierra. The truck has a 4.8L engine, automatic transmission and 4wd. Current HWY average is 20-21 mpg US.
Highway cruising speed is consistently 105 km/h and terrain is varied on my weekly round trip that totals 550km. This is a 225km one way trip from my hometown to work.
The idea for the aerolid is following along design that Bajascoob used. I bought 100' of 1/2" tubing for $29.00 CAD and will try using some leftover 6mil vapour barrier plastic that I have.
Total costs so far:
1/2" EMT $29
1/2" EMT bender $50 (Gotta have the right tools )
Angle indicator $22
The basic layout will be similar to Bajascoob's unless there have been any inherent faults with that design so far. A basic tapering down and in towards the tailgate will offer a rudimentary "boat tail" to the lid. I plan to have it hinge up at the front like a solid tonneau if a good strong design comes together.
So far it looks like I'll have a 12 degree slope from cab to tailgate. I'll have to hump it a little just after the cab to prevent a sharp angle change and cause airflow separation. Here are some pics of what I've started with.
Name:	IMG00120-20100429-1721 [50%] [50%].jpg
ID:	5988   Click image for larger version
Name:	IMG00122-20100429-1722 [50%] [50%].jpg
ID:	5989   Click image for larger version
Name:	IMG00123-20100429-1722 [50%] [50%].jpg
ID:	5990   Click image for larger version
Name:	IMG00121-20100429-1721 [50%] [50%].jpg
1994 electricfly EV conversion 36V/450A/60km/h
1997 Suzuki Sprint hatch (parts car?)
1998 Geo Metro sedan 1.3L auto (the wifes)
2009 GMC Sierra 27us/mpg best yet (still workin on it)
Old 04-30-2010, 07:05 AM   #2 (permalink)
Looks like a good start. Do you think it would create too much turbulence if you lower the front top edge enough to allow those behind you to see your third break light? Or will it be visible through the plastic? Or could it be relocated to the top center of the tailgate?
I've seen so many cases where one break light has burnt out and when the driver pumps the brakes it looks like a turn signal. I really appreciate the third light.
Old 05-01-2010, 01:31 AM   #3 (permalink)
Aero Apprentice
swede's Avatar
Plans are to have a third light on the rear deck lid of the cap. There will be more pics of construction as the weekend progresses.
Initial tests of 6 mil plastic were disappointing, less shrink than expected but good self welding characteristics. Too bad.
I'm now looking at clear coroplast or lexan. I may have a hook up for a skid (pallet) of lexan and umhw plastic cut off's from a family hookup, (brother in law).
If this works out I am hoping for a Lexan shell. If I cant get the plastic soon enough I will go to Home Depot and get white or clear coroplast for the test run.
Old 05-01-2010, 09:30 PM   #4 (permalink)
Aero Apprentice
swede's Avatar
Continued
Pictures of the framework construction. All joints are welded, no connectors used.
Name:	IMG00126-20100501-1149 [50%] [50%].jpg
ID:	5995   Click image for larger version
Name:	IMG00127-20100501-1149 [50%] [50%].jpg
ID:	5996   Click image for larger version
Name:	IMG00128-20100501-1150 [50%] [50%].jpg
ID:	5997   Click image for larger version
Name:	IMG00129-20100501-1252 [50%] [50%].jpg
ID:	5998   Click image for larger version
Name:	IMG00130-20100501-1252 [50%] [50%].jpg
Name:	IMG00131-20100501-1252 [50%] [50%].jpg
Old 05-01-2010, 09:53 PM   #5 (permalink)
Aero Apprentice
swede's Avatar
Sourced some black coroplast for 30 dollars for 2 4x8 sheets. Covered the frame with it and riveted it on. The rivets tended to pull out of the plastic a little too easy so I made washers out perforated strapping and uses the strapping to edge the major stress areas around the corner bends. 1/8" pop rivets are used to fasten the entire perimeter of the covering.
More pics.....
Interior view showing framework. Pipe insulation keeps the box rails from getting beat up.
Exterior showing coroplast. My first time working with it. I found that a heat gun and carefully bending the radius of the corners prevented major kinks.
A few pics of the back showing the fastback style raised edge. This was done in an attemt to "boat tail" air flow. Some bubbling issues with the plastic on the sides. I may add additional braces and fasten it on the sides.
Here it is on the truck. There are four stakes that drop into the trucks stake pockets. Ratchet straps fasten it down into the the bed from the cargo tiedowns in the box.
If it works well I will design a hinge from the front to allow it to raise up like a solid tonneau cover.
I will be very closely monitoring fuel consumption for the next while and will post results here as I get them. Barring no major headwinds, typical fuel consumption ranges from 19-21mpg hwy most times.
Total cost to date for supplies (not including tools) $70.00 tax included.
Comments and suggestions welcome!!
Thanks
Swede
Name:	IMG00132-20100501-1707 [50%] [50%].jpg
ID:	6001   Click image for larger version
Name:	IMG00133-20100501-1707 [50%] [50%].jpg
ID:	6002   Click image for larger version
Name:	IMG00134-20100501-1707 [50%] [50%].jpg
ID:	6003   Click image for larger version
Name:	IMG00135-20100501-1707 [50%] [50%].jpg
ID:	6004   Click image for larger version
Name:	IMG00136-20100501-1715 [50%] [50%].jpg
Name:	IMG00137-20100501-1800 [50%] [50%].jpg
Old 05-03-2010, 06:00 PM   #6 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Looks great. Nice work, I hope you see some positive results. For anyone welding EMT, be sure to wire brush off the galvanized coating and/or weld in a ventilated area.
Do you have a rough estimate of the weight of the AeroLid?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 05-03-2010, 06:12 PM   #7 (permalink)
Aero Apprentice
swede's Avatar
Welding galvanized steel is not something to be undertaken by someone who is not aware of the dangers of zinc poisoning. When I welded the skeleton together I was in a garage with a good crossbreeze and I didn't hover in the path of the welding smoke, rather staying back a bit and letting the smoke get blown away.
The AeroLid wieghs in at less than 30 lbs, probably around 20lb. I havent weighed it yet but I can lift it up with one hand and mount it on the truck easily myself (two hands).
Old 05-03-2010, 09:50 PM   #8 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
it is probably a good suggestion to use a respirator or exhaust system. If you avoid contact with the smoke, its reasonable, but precautions never hurt anyone. By the way, I teach high school shop.
Old 05-03-2010, 10:56 PM   #9 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Nice job. How do you plan on making it hinged? I was thinking it would be best to have the hinge at the top with a frame to support it while it's up.
I wonder if there is any difference in gains between a longbed and shortbed with a cover like this.
Old 05-04-2010, 12:26 AM   #10 (permalink)
Aero Apprentice
swede's Avatar
That's exactly what I had in mind. I plan on making a "headache rack" type frame with hinges at the top and gas struts to support the lid while it is up. The only challenge will be figuring out how to prevent the bottom front edge from hitting the box rails due to the lower swept arc as the lid opens. I'll have to think up some fancy hinge geometry for that I guess.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Build Thread: 1996 Ranger 2.3L 5spd 2WD XVTer EcoModding Central 18 05-27-2012 08:39 PM
The Little Red Build Thread Oval_Overload EcoModding Central 37 09-30-2010 06:19 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
