Old 03-16-2014, 09:29 AM   #21 (permalink)
Oh I am quite serious about fuel economy, and I have saved up enough funds with that in mind. In terms of a custom build, what "exactly" would that involve? What should I have the engine builder do?
Old 03-17-2014, 01:04 PM   #22 (permalink)
I wrote a lengthy reply but when tried to post it directed me to log on again. All that I wrote was lost.
Always Select All and Copy before you click Post or Advanced.
Always.
Mista Bone (03-20-2014)
Old 03-19-2014, 03:05 PM   #23 (permalink)
Best bang for the buck is to find a d15b 3 stage vtec and have someone chip a p72 obd1 ecu to utlitize the iab to engage secondary vtec and leave the actual vtec engagement alone. Have them tune it to lean out part throttling and you should be good to go. To read more on this please direct your web browser to d-series.org. We have some people there who have had great success going the chipped ecu route and others able to find the proper obd2 ecu and did all the wiring to either obd0 or obd1. This engine utilizes an egr but does not need a wide band o2 like the VX model, which is a damn good plus.
edit: I have to add that if you decide to go the chipped ecu the egr is not used but you don't have to waste your time finding an intake manifold with no egr. Mine is just sitting there not used.
The Following User Says Thank You to tony_2018 For This Useful Post:
Old 03-19-2014, 03:14 PM   #24 (permalink)
KrautBurner's Avatar
Cavalier of D00M - '05 Pontiac GTO LS2 T56
90 day: 23.2 mpg (US)
The New One - '10 Toyota Prius II
90 day: 51.55 mpg (US)
Chick Magnet - '91 Geo Metro 3cyl/5sp
90 day: 48.07 mpg (US)
I'd go talk to the local speed shop
not everything they touch has to have a bumblebee fartcan exhaust
and
keeping your money local is always a good thing
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Old 03-21-2014, 07:39 PM   #25 (permalink)
and
I second the local part, believe me.
Old 03-21-2014, 08:44 PM   #26 (permalink)
It's also a lot easier to go back to someone local when you have a problem with whatever it was they did for you.
-soD
