Old 05-20-2011, 08:40 AM   #21 (permalink)
Corrado TDIsm - '90 VW Corrado TDI
90 day: 44.76 mpg (US)
Here is a how to from disabling the DTRLs:
Its much simpler than any other method as you can see after watching the video.
Thinking about a TDI swap? Review the TDI swap directory
Old 05-21-2011, 05:14 PM   #22 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Simpler? yes. Catch all? no.
there are two different methods, because there are two different beetle setups.
BOTH are on the link that I posted that began the thread.
again with the second guessing! What am i? jeeze!
Old 05-21-2011, 11:46 PM   #23 (permalink)
daily transport - '00 vw golf tdi
90 day: 69.33 mpg (US)
Originally Posted by G60ING View Post
I disabled the day time running lights on my mk4 2003 Jetta by bending one of the electrical pins over on the headlight switch. Some have removed the wiring from the plug side and others have covered the pin with electrical tape. I wanted it to look stealth and the elctrical tape didn't work for me.
It was very easy to do but I can't recall what pin number it was since I did this back in 2003.
I just went ahead and snapped mine off. Took me about 2 minutes.
Old 05-22-2011, 03:55 AM   #24 (permalink)
The PRC.
There must be a fuse, just pull it.
Old 08-15-2011, 02:09 PM   #25 (permalink)
Definately a Modder!
I disabled mine quite awhile ago. Really glad I did-at the very least it saves my headlight bulb life
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
The Following User Says Thank You to Josh8loop For This Useful Post:
SwamiSalami (08-15-2011)
Old 08-15-2011, 02:14 PM   #26 (permalink)
The PRC.
That accepted I read somewhere that bulbs last longer with use. Car bulbs that is, not house ones.
Old 08-15-2011, 05:32 PM   #27 (permalink)
Escape #2 - '13 Ford Escape Titanium
C-max - '17 Ford C-Max SE
DRL's are only mandatory in Canada - if you happen to do this mod and then drive to Canada for a vacation, just turn the headlights on until you come back, that's legal as well for temporary use. You just cant import a vehicle permanently without them, or drive without either headlights or DRL's on there.
Whether or not the vehicle has DRL's in America is completely up to the manufacturer. ALL GM vehicles since some time in the mid 90's have had DRL's, while very few (if any) non-fleet Ford vehicles have them, even for the current model year.
Old 08-15-2011, 09:11 PM   #28 (permalink)
Easter McoModder
This is another great example of why disabling drls is totally worth it.
Old 08-15-2011, 09:12 PM   #29 (permalink)
Easter McoModder
show me.
Old 08-15-2011, 09:40 PM   #30 (permalink)
Kind of interesting that if you look at a DC powered light bulb you will notice over time that the inside of the bulb gets a silvery coating. Know what that is? It's bulb material that has been sputtered from the filament and coated the glass. There is low pressure inside the bulb that allows the filament to reach a high temperture(hence white light) without burning out. Low pressure and heat can cause material migration.
daytime running lights, drl, new beetle drl, tdi drl
