Old 05-10-2022, 08:58 PM   #441 (permalink)
try BMW
BMW has been using a system for years that shuts off the alternator.
they claim a few % extra MPG.
The computer shuts off the alternator if battery charge is ~ 80%.
The other 20% kicks in the alternator when braking thus providing charge and some small regenerative / retarding effect.
The system has a name, but it escapes me now.
Old 05-10-2022, 09:38 PM   #442 (permalink)
90 day: 29.78 mpg (US)
Originally Posted by sregord View Post
Having read this forum, It seems that a cleverly automated or manual switch on the alternator power lead(off up hill&level-on downhill) could be a fuel saver…. 10% would bring this up to- wow -almost 9 mpg.
Unfortunately it doesn't scale like that. Maybe disabling the alternator on a super efficient car like the Honda Insight could improve fuel economy by 10%, but electrical loads represent a smaller portion of total energy use in larger vehicles.
Kinda like how I could tell when my AC kicked on in my old and weak Subaru. AC represented a larger load on that vehicle than, say, my 7,000 lb Dodge Ram 2500 diesel.
That said, seems a worthwhile project since the solar is already installed and available to be utilized.
Old 05-11-2022, 02:31 PM   #443 (permalink)
EcoModding DIY aer.or
Thumbs up
Thank you... little bits here and there.
I was going down the 65+ Efficiency Mods ...& this one caught my eye.
Been working on my hyper-milling skills too.
Addressing aerodynamics of a big box? there could be some improvements, but not many. Been looking for a stream here that could be scaled up from a van.
So far the rear is "feathered" with the vortex generators, not sure if we've gained any efficiency, but being around semis has definitely improved.
Old 05-11-2022, 03:25 PM   #444 (permalink)
Like this?
https://www.dfrc.nasa.gov/Gallery/Ph...uck/index.html
I know aerohead has analyzed this in the past, here is one specific thread. ecomodder.com/forum/showthread.php/plan-my-cargo-trailer-30395.html#post453403
Long story short, the brick is the same on the underside. I posted about my design for a semi-rigid boat tail after you posted about the Trucksack in 2020.
Old 05-11-2022, 07:43 PM   #445 (permalink)
Yes,
I have reviewed the NASA historical data.
Not sure this is the right Forum to continue this.
I'll get over to the "Class a motorhomes aerodynamics stream"
..and we can continue..?
Old 05-16-2022, 12:38 PM   #446 (permalink)
Buggie - '01 Vw Beetle TDI Gls
How about adding a super small crankshaft pulley and larger pulleys on both the water pump and alternator, a reverse under drive setup.
Old 05-16-2022, 12:44 PM   #447 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Does the alternator work less hard when the 12v battery is fully charged?
Old 10-26-2023, 12:01 PM   #448 (permalink)
EcoModder returning
Yes, the alternator doesn't have to work
at all if batteries are fully charged. However, most generate a little power to keep their "field" charged. It depends on the alternator I'm sure. I doubt maintaining that field is even measurable as a belt driven load.
Old 10-26-2023, 12:15 PM   #449 (permalink)
EcoModder returning
Old 10-26-2023, 12:37 PM   #450 (permalink)
EcoModder returning
I've tried to read this whole thread yet ran out of time. Am wondering if anybody has addressed, what I recall from my misspent youth, vacuum driven alternator cut-outs.
I remember they had a adjustment screw. Maybe they could be set so low that the alternator would only cut in during idle or braking. I don't know if anybody has experimented with this or can show any real cost benefit. I know many of us like to experiment.
Of course they wouldn't do anything for oil burners yet might deserve a re-boot with us. I've been looking on FleaBay for some NOS vacuum cut-outs yet haven't found any.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-09-2010 11:41 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
