Old 07-25-2012, 03:48 PM   #41 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Just as an FYI for everyone doing CFD. The more correct the data you feed your simulation the more accurate results you will get.
I have been playing with the model of my car to get it right. I just did a check on the underbody airflow. At the bottom of the picture you can see where I have made the front wheel well more like my car. It has less flow separation (and less drag) than the front wheel at the top of the picture. Also the stream lines diverge less from the lower front wheel (also indicating less drag). Small changes can have a big impact on what your being shown and thus the conclusions you make from your model.
The Following 3 Users Say Thank You to ConnClark For This Useful Post:
aerohead (10-13-2012), Cd (07-28-2012), KamperBob (07-26-2012)
Old 07-25-2012, 05:08 PM   #42 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
any chance to test virtual AirTabs or other vortex generators?
Old 07-25-2012, 05:21 PM   #43 (permalink)
DieselMiser
ConnClark's Avatar
Once I get my model and simulation to show me similar stuff to what I observe in reality I'll test virtual vortex generators
Old 07-26-2012, 09:12 PM   #44 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
I'm digging your progress and enthusiasm. FYI, at a previous job coworkers did FEM for a living. They lived by the motto trust but verify. Results of any simulation not validated experimentally were taken with a grain of salt. Rock on!
Recreation Engineer
Old 07-27-2012, 11:39 PM   #45 (permalink)
That's really cool!!
Old 10-12-2012, 02:42 PM   #46 (permalink)
Focus (Stock) - '10 Ford Focus SE
90 day: 31.09 mpg (US)
Sonata - '04 Hyundai Sonata Base
90 day: 25.2 mpg (US)
The Van - '04 Ford Freestar SES
BRZ - '15 Subaru BRZ Limited
90 day: 30.71 mpg (US)
BRZ (E85) - '15 Subaru BRZ
90 day: 21.54 mpg (US)
Falcon preview extended.
I was wondering if Shortie, ConnClark or anyone else had any updates of their use with the software. Also brought this thread back up cause Falcon appears to have extended their preview till March 15, 2013. Gonna check it out later today!
You can find it by searching "autodesk falcon." (Can't post links yet.)
Old 10-12-2012, 07:22 PM   #47 (permalink)
DieselMiser
ConnClark's Avatar
I'm still plugging away at it. I don't have enough memory to brute force things to get good results so I am tweaking my mesh at key places. My results are getting more believable.
Also here is a validation model with known wind tunnel results.
discussion
TUMWAER: Automotive
more discussion about the models
http://www.aer.mw.tum.de/en/research...otive/drivaer/
even more discussion with an email to request the models in IGES or STEP format.
http://www.aer.mw.tum.de/en/research...vaer/geometry/
a paper with CD and other info
http://delphi.com/pdf/techpapers/2012-01-0168.pdf
Old 10-12-2012, 09:44 PM   #48 (permalink)
EcoModding Smurfer
Smurf's Avatar
Dime - '95 Chevy S10 LS ExtCab RWD
Pickups
90 day: 18.23 mpg (US)
G/A - '96 Pontiac Grand Am
Team Pontiac
90 day: 32.74 mpg (US)
I got it to work.. After you SketchUp your design, go to File, Export, 3D Model.. Save it as a .3DS file. Open Falcon, click the car, import your design.
However, according to Falcon, an S10 like mine (with ridiculous body kit, courtesy of the Warehouse model) lowered with simple cap and angled nose can achieve a 0.37.. I tried it without the nose first, and it said 0.50 CD. Intriguing to play with though, thanks for the find.
Old 10-13-2012, 09:21 AM   #49 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I tried the software this morning with a model of a first generation Insight.
I managed to get the numbers pretty correct at a simulated .28, which had me really enthused, but the Cd varies so much each time you run the software you get a different number - actually it keeps going up and down as the software crunches the data.
What am i doing wrong ?
Old 10-13-2012, 12:11 PM   #50 (permalink)
DieselMiser
ConnClark's Avatar
Your doing nothing wrong. In simulations you have vortices that form and shed. these give rise to the fluctuations. What you have to do is wait until the oscillations get relatively steady and average the value you are looking for through a few cycles.
The Following User Says Thank You to ConnClark For This Useful Post:
Cd (10-13-2012)
