Old 03-11-2013, 12:15 PM   #61 (permalink)
Eco Sol
Shortie771's Avatar
Well. with only 4 days remaining on this software, I think I am out of time to try to figure out any accurate numbers on CFD. On top of that, I am going camping until friday, so that gives me only today to use the software before they cut it off.
It was fun while it lasted. I did find out 1 good thing about my car while using it. The mirrors on the Del Sol really mess with the airflow, in a bad way. They manage to seperate a lot of air from the sides of the car which doesn't have enough time to re-attach annd it generates a lot of turbulance. I will definitely be looking at a mirror delete (either interior mirrors or cameras) in the future. On the note of cameras (not meaning to get too far off topic), has anybody actually done cameras as side view mirrors? I have searched the forums and have only found talk, with no action or pictures.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 03-12-2013, 10:47 AM   #62 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Thanks for your efforts. (Happy camping!)
Recreation Engineer
Old 03-28-2013, 12:52 AM   #63 (permalink)
gil
gil's Avatar
The Drift - '85 Toyota Corolla GTS
90 day: 28.26 mpg (US)
!Rally - '02 Subaru Impreza WRX
90 day: 27.68 mpg (US)
Cinnamon - '13 Honda PCX 150
90 day: 75.86 mpg (US)
Trial was extended, expires August 2013.
I had to intall DirectX End-User Runtime Web Installer
for it to work on my Windows 7 Laptop.
Gil
Old 03-28-2013, 01:00 AM   #64 (permalink)
Eco Sol
Shortie771's Avatar
Gil
Thanks for the notice. Guess I can test a few more things
CR-Z Current Mods:
Max Sidewall PSI
Old 03-28-2013, 01:30 PM   #65 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Looks like autodesk is finding that real CFD codes are difficult to work with and verify
Old 03-28-2013, 01:43 PM   #66 (permalink)
Eco Sol
Shortie771's Avatar
Lucky us
CR-Z Current Mods:
Max Sidewall PSI
Old 03-29-2013, 04:44 PM   #67 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I am going to try this. The download is going now.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 03-29-2013, 04:48 PM   #68 (permalink)
Eco Sol
Shortie771's Avatar
GREAT!! I look forward to seeing your results. I have been hoping that more people would post some results on this, because I just don't currently have the time to be messing with the 3D models (very times consuming) and my grill block I have been working to perfect, plus all of the every day things in life I have going on.
If you get anywhere with it please post some pics on here of what you have been able to accomplish. Or any issues you are having with it, so that others may also be able to learn from it.
CR-Z Current Mods:
Max Sidewall PSI
Old 03-29-2013, 10:14 PM   #69 (permalink)
Team Pontiac
I tried the falcon and it only does 2d. I select 3d but it won't do it.
I can't even find a 3d model of a sunfire and I don't have time to make one.
I did run some tests in flow simulator and got these. It seems that removing the spoiler and air dam might give the best results. I waited until the flow stabilized before I took the shots.
Name:	sunfire bare trunk.jpg
Name:	sunfire no dam.jpg
Name:	sunfire stock.jpg
1991 F-250:
Old 03-30-2013, 11:53 AM   #70 (permalink)
Eco Sol
Shortie771's Avatar
Did you read the first post in this thread? That doesn't look like falcon to me... Maybe it is just because I haven't used a 2D model in Falcon
CR-Z Current Mods:
Max Sidewall PSI
