View Poll Results: what tires do you suggest?
stock size cheap tires $41 ea 3 23.08%
step up Falken Sincera SN-828 at $50 ea 0 0%
Top Tier Michelin Defender $101 ea 7 53.85%
step up to 185/65-14's Ohtsu FP6000 A/S for $45 each 0 0%
step up to 195/60-14's GT Radial Champiro VP1 for $44 0 0%
other... please post info 3 23.08%
Voters: 13. You may not vote on this poll
Old 03-27-2014, 11:39 PM   #31 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
goodyear fuelmax P185/65R14 and you should be able to get a $40rebate
Old 03-28-2014, 10:59 AM   #32 (permalink)
KrautBurner's Avatar
Cavalier of D00M - '05 Pontiac GTO LS2 T56
90 day: 23.2 mpg (US)
The New One - '10 Toyota Prius II
90 day: 51.55 mpg (US)
Chick Magnet - '91 Geo Metro 3cyl/5sp
90 day: 48.07 mpg (US)
looks like those go for $100 each
Goodyear Assurance Fuel Max Tire P185/65R14 - Walmart.com
that makes them about $550 for the set
the General's I ordered (should have them installed monday) were $65 each
that's about $350 installed (after Labor and Tax)
and they have a $100 rebate
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Old 03-28-2014, 12:42 PM   #33 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
As rolling resistance data is closely guarded, one default you can assume is that the OEM rubber is the lowest RR you are likely to find. This is data the OEM has to submit to the EPA to get an MPG rating and as MPG ratings are often sales points, the OEM has a reason to use the lowest RR tires possible.
Keep the skinny tires.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 03-29-2014, 07:52 AM   #34 (permalink)
Tire Geek
CapriRacer's Avatar
Big Dave,
I hope you understand that I am trying to correct a misconception and I'm not picking on you or your post. Just merely trying to get the facts straight.
Originally Posted by Big Dave View Post
As rolling resistance data is closely guarded.........
It's more like there are several ways to express RR and there is no agreement which test to use. In other words, different tests yield different results, so unless the tests are the same, you can't be certain of any particular value that is quoted.
And rather than get into a pissing contest with their competitors, they've chosen to be purposely vague.
....., one default you can assume is that the OEM rubber is the lowest RR you are likely to find.......
This is very likely true. I don't know of any tires that have truly low RR values that aren't OEM.
........... This is data the OEM has to submit to the EPA to get an MPG rating..........
Actually, the RR values aren't submitted. The overall vehicle test results are and the tire's RR value as well as the engine's efficiency, transmission losses, etc. all contribute to the value obtained. The tire's RR is just little bit of the overall picture, but the government doesn't know what the RR values are (unless they test them themselves.)
...... and as MPG ratings are often sales points, the OEM has a reason to use the lowest RR tires possible........
Well ...... sort of. RR is part of the technology triangle where traction and treadwear form the other legs. Any improvement in one area is done at the expense of another area. It's a delicate balance that vehicle manufacturers sometimes get wrong - one of the reasons why OE tires are generally considered "poor quality". But OE tires aren't always the lowest RR values possible - sometimes the vehicle manufacturer will emphasize traction in order to impress journalists.
......Keep the skinny tires.
Skinny isn't so much the over-riding factor in RR. There are other things that have a much larger effect.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 03-29-2014, 03:48 PM   #35 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Also remember that when talking only rolling resistance in same tire size effect to fuel consumption is only max 7-8% better fuel consumption between best and worst. Now you can easily make calculations is it worth to buy brand tires or not. Based on Finnish tire magasize tests usually it is as brand tires tend to last up to twice the miles longer.
I would not fully trush the wear ratings or what you think Capriracer is there some legislation that manufacturers cannot lie on that rating?
If you open the door to changing size totally different the bigger diameter (longer distance travelled) and aerodynamics (narrow) effect more than the LRR compound.
I would go for 175/80R14 if you can find a good set (if your state laws allow them). In finland you can find over 35 manufactuers for that size so there must be some importers to US also... At least in Finland you can buy used set easily 50-100$ so you can test their effect. If they dont work sell them and buy different size.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-30-2014, 07:57 AM   #36 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Vekke View Post
........I would not fully trust the wear ratings or what you think Capriracer is there some legislation that manufacturers cannot lie on that rating?........
Well, sort of.
The tire manufacturers can not OVER state the wear rating - and they have to do the comparison to a standard tire (so you can compare between brands) - BUT - not only can the tire manufacturers UNDER state the wear rating, they can run the test a number of times, selecting the best result (if they want). Or they can run the test such that the comparison to the standard tire is through multiple tests, taking advantage of the error in each test.
So while you can compare treadwear ratings, you have to take them with a grain of salt. There is probably little difference between tires rated within 10% of each other (say, 400 vs 440), but there will be a difference between tires rated more than that (say, 300 vs 400) - keeping in mind that understating the wear rating is possible.
........If you open the door to changing size totally different the bigger diameter (longer distance travelled) and aerodynamics (narrow) effect more than the LRR compound.....
I thoroughly disagree. The RR of tires in the same size can vary up to 60%. Small tire size changes are on the order of a couple percent. Tire aerodynamics is even smaller. Gearing changes due to tire size might have a larger affect, and probably worth the trouble, particularly considering there are 2 things going in the positive direction (gearing and RR)
CapriRacer
Old 03-30-2014, 10:59 AM   #37 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Rolling resistance can be bigger % change but the effect to fuel consumption is max 7-8% at least what I have seen in local magazines (been following the tests over 4 years perioid summer and winter tires) and they have usually one or two reference tires of chinese marks (non brand) just to see the level of their performance.
This years test had 16 tires and biggest difference was 6% to fuel consumption. and the suprice performer was Landsail LS288 which outrun few of the brand tires in some tests. That tire set reference price was 350€ 8.6 points of 10 vs winner Continental Contipremium Contact 5 550€ per set 9.5 of 10. tested size was 205/55R16
