Old 07-13-2017, 10:41 AM   #21 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
I don't ask much from mine. Instant and Average MPG, intake vacuum, coolant temp, O2 voltage (for lean burn indication). The MPG readings are pretty significantly different from what the car itself reports, I think due to the app not understanding the hybrid Civic properly. I may not have configured the app correctly but it at least keeps me up to date on trends, which is enough for behavior modification.
Old 06-28-2021, 06:10 PM   #22 (permalink)
CVTCivic's Avatar
CVTCivic - '17 Honda Civic 4D Touring Sedan
90 day: 39.16 mpg (US)
Just tried a few for the first time today, but most of them did not work:
Old 06-28-2021, 08:03 PM   #23 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Hmmm I never have used that app. I have a gauge that plugs into the OBD2 port. Hopefully someone replies for you.
Old 06-29-2021, 10:09 AM   #24 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
The most common culprit is a bad obd2 adapter. Next place to look is which protocol is being used.
Old 06-29-2021, 10:10 AM   #25 (permalink)
Torque and kw are calculated and will only show when accelerating IF you have vehicle information filled in the vehicle profile.
The Following User Says Thank You to ksa8907 For This Useful Post:
CVTCivic (06-29-2021)
Old 06-29-2021, 05:25 PM   #26 (permalink)
CVTCivic's Avatar
Question
Do you know how I can find out which protocol I should choose?
Old 06-30-2021, 08:13 AM   #27 (permalink)
You should use automatic, unless you believe something isn't working properly. Also and FYI, not all data points will be supported by your ECU.
CVTCivic (07-03-2021)
Old 07-03-2021, 02:59 PM   #28 (permalink)
CVTCivic's Avatar
Alright, thank you. That's the list the Torque pro app can read from my ECU.
Old 07-05-2021, 05:44 AM   #29 (permalink)
CVTCivic's Avatar
Turtle
I did test some new gauges, now at least most of them work. For some of them I don't even know what they mean.
My biggest hope was that the gauges were more accurate than what my "vehicle information display" shows. For example the "remaining fuel (percentage)" and "remaining distance left (kilometers)"
But unfortunately they're not. If it shows "0 kilometers left", there are still 7 liters in the fuel tank, which means I can easily drive another 100 kilometers.
Old 07-05-2021, 11:02 AM   #30 (permalink)
Those are always wrong for me also, I don't use them. I think it is because they are calculated by the app and not read from the ECU.
zippy97 (09-19-2021)
