Old 02-17-2018, 01:27 PM   #1 (permalink)
Trailer Hitch For One Wheeled Trailer
Allows the trailer to bend left or right to track the car around corners, and tilt up and down, to follow grade differences between the trailer and car (Driveway ramps, for instance), while not allowing the trailer to fall over on it's side:
Name:	2011 prius U-Joint.jpg
Old 02-17-2018, 03:17 PM   #2 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
If the hitching U-joint is mounted High Enough the pendulum effect will make it always want be belly down due to center of gravity.
The only downside to this is as the car pitches side to side it will force the tire to scrub left and right the distance based on the separation of the U joint and the tire. This is really insignificant as far as fuel economy goes ,as usually a driver is going under 10 mph when these type of terrain situations are encountered.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 02-17-2018, 03:56 PM   #3 (permalink)
The hitch will be mounted half way up. The trailer front will be a hemisphere sitting in a shroud which has a circular cut in it to snug the trailer front into. (See Illustration below)
Dips in roads at speed need to be accommodated. The hitch will act just like a ball hitch to allow pitch and yaw changes freely, but like a solid shaft to allow no roll.
Name:	2001 front of trailer.jpg
Old 02-17-2018, 09:13 PM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
That means you're going to have to reverse it like a trailer too.
Not so easy when you can't see it at all.
The pivoting caster wheel concept is the most popular single wheel solution for a reason.
Old 02-17-2018, 11:18 PM   #5 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
This is what I mean by roll scrub
Of corce the sight wants the picture sideways, ough.
I don't think it will add much if any strain on the system. Only side effect I can see is the single fixed Tire having a tendency to try and turn. similar to how you steer a motorcycle by leaning ( even drag bikes with 12" wide back tire that is square as a car tire still leans to induce the effect I'm speaking of, for turning).
Any ill effects would be most noticeable while high G-Force turning or severe side wind that causes body roll.
The greater the distance from the Roll center of the car and the U-joint Mount point the greater this effect will be. The Pivot Point must be at a central location as per the body shape and proportions through design you may be able to cheat this location towards the Roll center to minimize any ill effects. This is along the lines of what I was thinking as far as being able to do a one wheeled trailer behind a motorcycle/ bicycle.
Former
87' Hyundai Excel
Old 02-18-2018, 03:24 AM   #6 (permalink)
I will be using a rear view camera in the collar. In it, the trailer will be visible.
Old 02-18-2018, 03:29 AM   #7 (permalink)
Why would a two wheel trailer not have this problem?
Old 02-18-2018, 04:46 AM   #8 (permalink)
OK, how do I find the roll center of a Gen 3 Prius? f I have to, I'll re-position the U-Joint.
Old 02-18-2018, 05:44 AM   #9 (permalink)
What are you going to be using for a wheel?
I don't think I have ever seen highway service bearings and tire on a caster.
Then how easy will the tire be to change?
I have had a flat on my regular trailer. I had a hydraulic jack and my 1/2 drive ratchet, took less than 10 minutes to change.
I have worked on these larger casters before and I hate changing tires on them. When you pull the idler shafts out you have to open up the bearings, potentially exposing them to dirt if done on the side of the road.
Have you ever worked on one before?
freebeard (02-23-2018)
Old 02-18-2018, 10:51 AM   #10 (permalink)
Changing a flat would be more difficult. I suppose an axle pin that can be pulled out one side could make that simpler. the only reason for a single wheel and tire is to keep the rear of the trailer as slim as possible,(license plate slim, in my case) but if the wheel(s) were moved forward to a wider part of the trailer, a single frame rail with a drastically shortened axle mounting two wheels in the conventional hub mount manner could be used. Not sure how that would affect tail wag. I prefer to keep a single wheel as near the rear of the trailer. Another option would be dropouts (with a lock cap, as on the lower end of a piston rod) to allow the wheel to be removed like a bicycle front wheel.
