Old 09-28-2014, 07:48 PM   #21 (permalink)
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by 2000mc View Post
So, you say your car seems to get better mileage when going downhill?
No I never stated this as fact. I merely stated that by observation of the gauge itself that it shows my vehicle's mileage increases going downhill either coasting or with light engine load. It may be incorrect, but this is just what I have been observing for the past month.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
Old 09-28-2014, 07:50 PM   #22 (permalink)
Originally Posted by Old Tele man View Post
...that's *WHY* I prefer to continuously collect data (via computer) so that it can be subsequently filtered and analyzed to account for "out-lier" data points (single item) and periods/trends (climbing hill; coasting downhill; etc.).
Now that is wise! May I ask exactly how you track this information separately? I ask because the UltraGauge does not keep a logbook sort of speak or have cycles to watch. Everything is reset to zero once the engine shuts off with the exception of the Average MPG gauge.
Old 09-28-2014, 08:24 PM   #23 (permalink)
...beats walking...
...using ElmScan-5 compact OBDII-to-USB interface cable, plugged into USB-port of ACER tablet CPU, and running OBDwiz software program. I then transfer the captured data onto a USB thumbdrive for transfer to 'big' desktop CPU for display, analyses, and "number-crunching."
Here is link to manufacturer, but I got mine thru Amazon for same price:
http://www.scantool.net/elmscan5-compact.html
Old 09-28-2014, 08:50 PM   #24 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Your car should most definitely get significantly better mileage going down hill, or when coasting / light load.
This would also be why you can see a higher mpg at a higher speed when coasting. When coasting your car will only consume engough fuel to keep the engine spinning with no load, at that relatively fixed rate of fuel consuption, if your car happens to be moving at 80mph while coasting, your instant mpg would probably be near double that of coasting at 40mph
The Following User Says Thank You to 2000mc For This Useful Post:
SilverCrown9701 (09-29-2014)
Old 09-28-2014, 10:30 PM   #25 (permalink)
Old Teleman, do you use something like this with your Elmscan and laptop?
http://www.amazon.com/AutoExec-Wheel...dp/B00E1D1GY6#
Old 09-29-2014, 09:40 AM   #26 (permalink)
I completely agree! DWL has certainly been useful.
What I don't like is having to use slightly more throttle to keep myself in top gear on relatively flat terrain with little to no wind.
Anything below 16 TPS and I start to slow down. It's truly aggravating.
Did you happen to see what I said about using cruise control?
Old 09-29-2014, 11:58 AM   #27 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
do a 65-45MPH Pulse and glide. and accelerate quickly for the pulse.
Old 09-29-2014, 12:10 PM   #28 (permalink)
I can pulse and glide in an automatic and still come out on top?
fuel economy, speed, ultragauge
