View Poll Results: For all you EOCers: after a cold startup, how long to you wait before EOCing?
Immediately
13 |
72.22% |
After the engine is idling normally
5 |
27.78% |
After the engine is fully warmed up
0 |
0% |
09-29-2014, 10:12 AM
Fusion - '16 Ford Fusion Hybrid SE
For all you EOCers: after a cold start when do YOU start EOCing?
I start once the engine is idling normally, when the cold engine enrichment mode is finished.
When preheating with my block heater, I start the engine at 115F on a 50F morning, and it takes about 30 seconds of running before it is idling normally.
When starting cold at work from 70F, it takes about a minute for the coolant to reach 100F and the engine to idle normally.
09-29-2014, 10:43 AM
In the Black Widow I would start EOCing within a hundred yards of my driveway, where the first stop sign is.
It's easier to re-start with a warm engine of course, but hey, gas is gas and if the motor isn't on you aren't burning any.
09-29-2014, 11:26 AM
Define 'fully warmed up'.
I'll first engine off once the coolant hits it's normal spot, plus a few km. I don't want more cold starts than necessary.
My Fiat has auto stop start and will switch of once the coolant reaches about 60*C, which is a bit low for my liking so I leave stop start off until 88*C (normal coolant temp).
In either case the engine won't be fully up to temp for many more miles.
09-29-2014, 11:31 AM
Rat Racer
EOC is more optimal than burning gas at any temp.
Except in the winter. Heat coming out of the vents is more optimal then.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
09-29-2014, 11:38 AM
Hypermiler
As soon as I reach the crest of the hill ~100 yards from my driveway. If you want good mileage, EOC is even more important at the start, because the ecu is programmed to burn extra fuel to warm up faster.
09-29-2014, 12:10 PM
I guess 'warmed up' can be broken into two levels: 'Operating Temperature' and "Fully Warmed Up', which are two different things.
Operating Temperature - thermostat opening temperature, which is 177F on my car, normal for a 180F thermostat in cooler ambient temperatures
Fully Warmed Up - thermostat opening temperature plus half an hour (or maybe an hour?); the time it takes for the engine oil to be fully warmed up and all the residual water/hydrocarbon vapours to be fully boiled off.
09-29-2014, 12:52 PM
Furry Furfag
+1. To me comfort from the cold outweights a few MPG.
09-29-2014, 01:03 PM
Hypermiler
In winter, I often don't reach "operating temperature", even after 10 miles. I employ the DWG technique.
Driving with gloves.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
09-29-2014, 01:06 PM
#9 (permalink)
Furry Furfag
Does Texas really get that cold?
09-29-2014, 02:37 PM
#10 (permalink)
Rat Racer
They think 40 is cold.
