Old 04-11-2012, 10:24 AM   #31 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I do not have much chloroplast leftover. There's a shop in auburn that sells 4 by 8 foot sheets.
You will find that smooth wheel covers out of plastic do not last. Get aluminum pizza pans.
Old 04-11-2012, 10:36 AM   #32 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
What happens to the plastic ones that does not already happen to the other aero mods? I assume impact damage?
I have kind of avoided any type of metal covers due to weight and figuring out attachment. If the plastic ones last atleast a year, I don't mind spending $6 a year to make them and a couple of hours .
Old 04-11-2012, 11:19 AM   #33 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
The suspension keeps a lot of abuse from getting to the rest of the car. Wheel covers, OTOH, have been falling off cars forever.
Transmission type Efficiency
Old 04-11-2012, 03:56 PM   #34 (permalink)
Wiki Mod
The zip tie method tends not to last More the a few weeks. When they come off it rtends to be at hi speeds and around other cars. I drilled and tapped my steel rims. That holds the pans on nicely.
Come over some time and I can show you what I did on my summer and winter rims.
Old 04-11-2012, 04:02 PM   #35 (permalink)
Did you use "cheap" zip ties? I'm pretty sure the ones I used have a small steel band inside them, so it isn't 100% plastic. Drilling and tapping the rims would probably work well .
Old 04-11-2012, 04:07 PM   #36 (permalink)
Wiki Mod
I have never seen zip ties with steel in them.
My steel rims looked bad so why not put alumunin pizza pans on. Drilling and bolting work well. I got alumin rims for my winter tires and I used 5 1/4-20 stainless bolts on each. That works very well. My three bolt summers work ok. But the pans rattle a bit.
If the zip ties work I have a family member who might use them. I would like to see how you did it. Pictures?
Old 04-11-2012, 04:19 PM   #37 (permalink)
I'm sure you saw this http://ecomodder.com/forum/showthrea...tml#post299551
I attached the plastic just by running the zip tie though the plastic, around the holes in the rim and back and zipped very tight. It literately ripped the coloplast a bit, but it don't have any slop. Movement = get ate away. Nothing really special except a high quality zip tie.
Old 04-11-2012, 07:15 PM   #38 (permalink)
Grasshopper - '11 Ford Fiesta SES
Team Ford
90 day: 50.37 mpg (US)
Feejer - '09 Yamaha FJR1300 AE
Motorcycle
90 day: 42.73 mpg (US)
I think hubcap design should be based on every seventies movie car chase scene. A car would make a sharp turn and a hubcap would fall off, only to magically reappear in the next scene.
Old 05-26-2012, 01:45 PM   #39 (permalink)
Wiki Mod
Well the story aired last night, I missed it but I have a link to the web version:
How to gain miles per gallon easily : News : miNBCnews.com
I am not sure if they will send me a dvd or not. if they do I might upload it
Old 05-26-2012, 01:52 PM   #40 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
I have mixed feelings on this article. The journalist did a good job of framing you as an active part of the FE game, but I'm not sure the article would be relate-able to readers with no ecomodding experience.
Boattails, side skirts, etc. All good, but foreign to most. On the plus side, the message is clear when he compares your real FE to the EPA. Maybe that powerful piece of information will help readers understand that they really to have power in terms of their personal fuel consumption.
Overall, it's good coverage. I hope they post the video to YouTube.
As the interviewee, what are your feelings on the article's portrayal of your pursuit, Ben?
EcoDriving: Turning more fuel into usable forward motion.
