Old 06-29-2010, 06:41 AM   #91 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
Originally Posted by Clev View Post
Which ones would those be? I believe the EV1 has the lowest consumption of a production EV at 179Wh/mi. The Tesla gets 240Wh/mi, and even Gary Graunke's Insight EV, which uses an AC drive system with regen, gets 185Wh/mi at 50 mph. The one that claimed 120Wh/mi, Aptera, released a press release on April 14 that revised the estimated consumption up to 200Wh/mi.
Reverend Gadget's GT6 bodied Spitfire uses 100 Wh/mile(from phone conversation with him). It is a very light conversion with the best LRR tires available, but nowhere near as aerodynamic as Dave Cloud's car. It's aerodynamics are definately much better than the average conversion, mind you, due to a very small frontal area(14.9 sq ft for GT6 body, 15.2 sq ft for spitfire MkIV body); it's drag coefficient isn't bad either, and is bound to be lower than the convertible Spitfire Mk I(streamlining and Car Aerodynamics by Jan P. Norbye quotes the MkI as 0.39, and various sites quote the MkIV Spitfire as 0.42). This car gets 24 miles range to 80% DoD on 15 Exide Orbitals at 60 mph; these batteries were measured by Rich Rudman as delivering ~270Wh each at the 1 hr rate, and Gadget was discharging them at about twice the rate!
John Bryan's VW Karmen Ghia needed ~100 Wh/mile highway. IIRC, it got 45-50 miles to 80% DoD on a pack of 16 Optima D750s, or a pack around 6 kWh at the 1 hr rate to 100% DoD.
James Worden's Solectria Sunrise, with extremely lightweight construction and similar, if not worse aerodynamics than Dave Cloud's Metro, could do 200 miles at 60+ mph on only a 27 kWh pack, which is 135 wh/mile. With hypermiling techniques, it set a world record of 373 miles on a charge, putting it well under 100 Wh/mile if driven carefully in city conditions.
Alan Cocconi's electric CRX, with some aerodynamic modification(Cd 0.25), got 135 miles per charge @ 55 mph on a pack of 28 Optima Yellowtops. I don't remember what his pack size was, but the car had a rediculously good efficiency(somewhere around 120 Wh/mile).
Other less efficient cars for comparison:
AC Propulsion's TZero, weighing in at 1900 lbs, and with aerodynamics nowhere near as good as an EV1(and probably worse than Gadget's Spitfire), consumed 160 Wh/mile at 60 mph, going 302 miles on that run before needing a recharge. Its tires have a Crr of 0.0085.
In the past, John Wayland's Datsun 1200, Blue Meanie consumed < 150 Wh/mile at 60 mph. Wayland quoted it many years ago that it used 55A with the pack sagging to 162V at 60 mph on level ground. It has brick-like aerodynamics(compared to say, a Honda Insight) and at the time weighed in at 2,340 lbs, although it made use of some very good LRR tires. This figure is also outdated; he has since upgraded the car.
John Wayland's other Datsun 1200, White Zombie, has thick, sticky drag tires, has the aerodynamics of a brick, and weighs around 2,300 lbs. It consumes an estimated 200 Wh/mile at 60 mph.
With regard to your above comments:
The EV1 achieved 179 Wh/mile on the EPA combined cycle; steady state cruising would yield different figures. At a steady 60 mph, the lead acid version used 164 Wh/mile and NiMH 168 Wh/mile. The EV1 was quite heavy, and probably has worse aerodynamics than Dave Cloud's car, even though the EV1's aerodynamics were exceptionally good and set a world record for a "production" car.
With regard to the Tesla Roadster, if you look at the Wh/mile versus mph chart on their blog, it consumes 250 Wh/mile at a steady 60 mph, with ~110 Wh/mile lost to aerodynamic drag, 80 Wh/mile lost to 'drivetrain'(including BMS, battery cooling, ect.), and 55 Wh/mile lost to rolling resistance. The Tesla has massive losses imposed due to keeping its battery at the proper temperature. The Tesla has mediocre aerodynamics and weighs in at 2,700 lbs, and has thick, sticky non-LRR tires. It is *not* an efficient EV, although it makes even a Honda Insight hybrid look like an energy hog by comparison. The Roadster's energy needs are about the same as Toyota's RAV4 EV!
Do you have links to Gary Graunke's project? I was extremely interested in it back in 2003, but pretty much dropped off the EV list around 2006. I haven't checked up on what became of that project and I am very pleased to hear that it is on the road! If its consumption is that high at 60 mph, I'd be extremely surprised. Then again, some conversions get far better or far worse efficiency than you'd expect...
The Aptera at 120 Wh/mile sounds about right, if not a bit high; initially I remember them quoting 120 miles range on a 10 kWh pack(87 Wh/mile), but their design has changed many times since then. 200 Wh/mile would probably be applicable for the "new" EPA highway cycle where cars are driven harshly to reflect those Americans who drive WOT all the time.
190Wh/mi is still very good.
Agreed; given that stock Metro conversions(stock with regard to aerodynamics) can achieve ~200-240 Wh/mile ~55-60 mph, the 190 Wh/mile figure seems a bit high, if measured from the pack; if measured from the outlet, or measured from the pack at 70 mph, it would make more sense.
Even some small lightweight trucks with poor aerodynamics are in the 250-300 Wh/mile at 60 mph efficiency range... even the 5,260 lb "Red Beastie" got around 300 Wh/mile at 60 mph. Surely, Dave Cloud's car has less than half its drag, and with about 2/3 its weight and LRR tires that "Red Beastie" didn't have, it should consume somewhere less than half of "Red Beastie" at the same speed.
The Following 2 Users Say Thank You to The Toecutter For This Useful Post:
aerohead (06-30-2010), Ulmo (07-02-2019)
Old 06-29-2010, 08:54 AM   #92 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Earlier in this thread, the car was reported at 170Wh/mi and 163Wh/mi in real world driving, and 120Wh/mi at steady state.
He mentions an 18% increase in Wh/mi due to a larger battery. How much battery weight does it have now?
Old 06-29-2010, 09:07 AM   #93 (permalink)
It has the full compliment of SIXTY 33lbs batteries, so ~1980 pounds of battery alone. The chassis is ~1,220lbs, including the battery frames, and the two motors.
I can try to find out the speed.
Old 06-29-2010, 11:16 AM   #94 (permalink)
Left Lane Ecodriver
How much battery weight did it have before? What I'm wondering, of course, is what % change in mass produces the 18% change in power consumption?
Old 06-29-2010, 12:28 PM   #95 (permalink)
I think it used 30 batteries, but half of them might have been heavier (~40pounds?). I think this info is earlier in this thread?
Old 06-29-2010, 05:40 PM   #96 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by The Toecutter View Post
(lots snipped)
Wow, I didn't know those numbers were available. I knew John Bryan got good mileage with his Ghia, but I didn't realize the numbers were that low. Too bad there's no place to put those numbers in the EVAlbum.
Those numbers are from the EVAlbum. His entry confusingly lists both the lead acid and lithium packs, but I think his Wh/mi ratings are with the Pb pack. I haven't seen him on the list since, and his website still says "To be continued..."
Speaking of, here's a bit of text from John Wayland that seemed like a great project, if I ever come into some money. This is from 2002:
Originally Posted by John Wayland
OK...the other Wayland idea....I've been toying with the ultimate conversion EV based on a space alein green Insight. 240V worth of the new, Optima sized 30 lb. Nickel Zinc batteries that have become affordable and available to we EVers recently, a Seimen's 106 hp AC drive system, Rudman PFC50 monster charger, and of course, the Wayland Signature sound system. The 2300 lb. EV would have a real world range of 130 miles per charge, could be fast charged in a pinch over an hour, or in 1/2 hour, be able to get an additional 60 miles of range, and the battery pack would have a 65-80k mile life expectancy. With a safe 10-12k rpm range from the light and powerful AC motor, the electric Insight could run from 0-100 mph in 2nd gear, and allowed to stretch out on an open highway, with the it's extremely aero wind cheating shape and lowered stance, in 3rd gear it would probably hit 130 mph or so!
The 0-60 time would be in the high 6 to low 7 second range with tire smoking torque (a limited slip dif. might be needed to keep the tires from being shredded too soon). Because of the special Nickel Zinc batteries, this would be an EV that has full power even in sub freezing temperatures, unlike lead acid powered EVs. I've already taken the measurements, and all of the batteries would fit in the IMA compartment under the hatch floor....no storage space lost. The under-hood area would be beautiful with the electric motor clearly visible and the inverter box neatly displayed.
Substitute LiFePo for NiZn and it sounds like an intriguing vehicle. He actually posted something later about being able to build trays that fit in all of the existing cubbies and holes, so essentially no holes would need to be drilled in the body.
Old 07-01-2010, 07:30 AM   #97 (permalink)
I spoke with Dave Cloud last night, and the Dolphin car he built with it's full compliment of sixty batteries, gets 130-140wH/mile at 60-65MPH.
KamperBob (07-01-2010)
Old 07-01-2010, 09:11 AM   #98 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Was that metered at the motors, or the wall outlet feeding the charger(s)? I would expect a substantial difference. With all the numbers thrown around I wonder about comparisons.
Cheers
KB
Old 07-01-2010, 09:30 AM   #99 (permalink)
Dave uses amp meter(s) in the car, while driving, I believe. These numbers are for the first 170 miles or so, IIRC. The voltage changes nearer the end of the run, so making the exact number a little harder to ascertain. I will ask about using a meter on the charger, which would be an average for the whole trip, but less approximate?
Old 07-01-2010, 09:46 AM   #100 (permalink)
Recreation Engineer
KamperBob's Avatar
Yeah, dropping from 12.6 to 12.0 is only 5% difference in battery voltage. Even with a 3rd decimal place the curve is nonlinear. Amplified across six in series it's still 5% (75.6 to 72). Unless the batteries have settled (cooled and equalized) terminal numbers can be iffy. Whereas a $20 Kill-A-Watt is easy. It read kW-hr directly and simple math gives utility cost per mile. Most folks probably recharge at home so it seems like a fair real-world benchmark.
Thanks again
KB
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
