Old 08-17-2012, 12:51 AM   #71 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Very cool.
I think I will do the same with 20ga cold rolled steel.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 08-17-2012, 06:00 PM   #72 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
there are drawbacks to using material other than coroplast. This was discussed at one point..
Metal will vibrate, rust, it's expensive compared to coroplast, heavier.....the list goes on.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-07-2012, 03:23 PM   #73 (permalink)
mcrews's Avatar
I am running just a front and rear belly pans.
here are some pics on the rear:
Curved cp up to meet underside of car. also show the cp taped to the wheel well
Passenger side rear wheel well
from directly under the bend in cp....
driver side rear wheel well:
driver side...used gorilla tape to seal cp to factory wheel well.
vent from closed off space:
looking from under passenger seat toward rear
ECO MODS PERFORMED:
First: ScangaugeII
The Following User Says Thank You to mcrews For This Useful Post:
aerohead (04-06-2013)
Old 04-03-2013, 06:32 PM   #74 (permalink)
Captain Planet
Smokey - '00 Honda Civic DX
90 day: 38.53 mpg (US)
Jade - '02 Acura RSX Type S
Muchas gracias mcrews for the loads of useful info and pictures! I sense a belly pan is in my future...
The Following User Says Thank You to Mira For This Useful Post:
mcrews (04-03-2013)
Old 04-03-2013, 09:25 PM   #75 (permalink)
mcrews's Avatar
Thank you for your kind words Capt Planet!
I recently sold the Q45 w 274,000 miles.
Those lasts pics were probably taken around 250,000.
And still looked like taht when it was sold.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-30-2013, 10:51 PM   #76 (permalink)
mcrews's Avatar
been missing the Q.........
REALLY miss the electronic suspension!!!
The Kia Sportage is nice....VERY well maintained for an 06.
But I have been looking at 06 Q45s on the internet......
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-01-2013, 07:41 AM   #77 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
awe man that sucks! why did you have to sell it?!
Thanks again for this amazing thread.
Old 05-01-2013, 03:12 PM   #78 (permalink)
mcrews's Avatar
I had busted up the front lip
I inherited the Kia Sportage from my daughter w 100k on it. The infiniti was at274k.
Also I had busted up the front lip on the IMPUL body kit and was becoming unhappy with thinks. Didnt want to put any money into it so sold it while it was still worth something.
for $11-14k I can pick up an 06 w/less than 100k!
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-11-2013, 04:59 PM   #79 (permalink)
I did an under engine cover for my Caddy LPG, but after finishing I immediately removed it as I made a test with a flame and discovered our Euro coroplast is soooooooooo flammable!
But maybe yours is different.
Going to redo it in with an aluminum sheet...
Wolf_Tm250 [Silat-Kali] - Parma (Italy)
Suzuki Gsx-R 600 naked
Toyota Rav4.1 Torsen: 240hp 3SGTE swap in progress
Toyota Celica Gt-Four ST205 Snowy White [2.34kg/hp - 600Nm@4950rpm]
EFI University Advanced Tuner
Old 05-11-2013, 05:04 PM   #80 (permalink)
mcrews's Avatar
Originally Posted by Wolf_Tm View Post
I did an under engine cover for my Caddy LPG, but after finishing I immediately removed it as I made a test with a flame and discovered our Euro coroplast is soooooooooo inflammable!
inflammable: not able to burn.
maybe you mean: flammable?
over 150k miles, not even a slight melt.
I can burnup a lot of things with direct flame..........
euro and U.S. coroplast are the same.
ECO MODS PERFORMED:
First: ScangaugeII
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
