08-23-2010, 12:30 AM
Using vapors from gas already going to carb?
What i want to do is route gas to a container and draw fumes out of there and also use that gas to go to the carb after.It would use 2 small fuel pumps,one to pump to the container and from there,another one to pump from the container to the carb.Would this way cut down on the quality of the gas at the carb? This will be for an 86 Toyota engine.
08-23-2010, 12:43 AM
I'd say, have a beer and do something else.
08-25-2010, 12:31 AM
I'm not sure, but it sounds as if you are trying to re-invent the carburetor, using the original, rejected design. EFI is darn near perfect as it is.
08-26-2010, 09:21 PM
the original design was made to draw vapors and use the gas that the vapors came out of? never heard of it.Do you have a link to this?
08-26-2010, 10:38 PM
No link handy, but early histories tell of carburetors made like humidifiers, with air being drawn through a chamber with fabric panels wicking up gasoline from a pool in the bottom.
09-08-2010, 11:11 PM
Sounds like something I read about before. google Tom Ogle.
Winter daily driver, parked most days right now
Summer daily driver
11-12-2011, 01:26 PM
Evil Genius
along the tom ogle thing, watch the documentary "gashole". it does a great job of explaining the tom ogle mystery (conspiracy).
i am an energy engineer and i am hell bent on developing a way to extend the range of CURRENT petrol engine technology. most of my testing is done on my 96 vw cabrio. propane conversion will be dont this spring, however, as i already have all the parts minus the tank, i am thinking about using the vapor carb to develop my own gasoline vapor draw system. a supercharger will be used to pump the vapor/air mix into the engine. fuel lines to rail will be blocked via servo/regulator assembly to avoid damage to the fuel pump and will possibly utilize the a/c system to vaporize and cool the vapor to avoid combustion outside of the cylinders. wanna use my ideas? go for it, some of them arent my ideas, im just building on some concepts ive heard about along with developing my own. this could be a great step if we can all make it work. shell oil company cant kill us all
11-12-2011, 01:50 PM
You're a what?
11-12-2011, 02:15 PM
#9 (permalink)
Evil Genius
energy engineer, i was a different kind of engineer before i went back to school (combat demolitions, then consrtuction) but now i study energy efficiency. engineers in my field study wind turbines, solar panels, hydrogen as a fuel, etc. im currently trying to make my hour drive to school a bit less fuel consuming.
11-12-2011, 02:17 PM
#10 (permalink)
Propane conversions are nothing new, and still depend on oil wells for their distilled fuel.
That's old tech.
Almost all improvements in fuel efficiency have been based on separating air and fuel for as long as possible - currently using direct fuel injection.
Another energy loss.
Cooling the vapor will result in fuel condensing again.
I'd say look elsewhere for improvements.
It's got to be good enough to substantially beat the now onrushing direct injection ... 70 years after WW2.
