Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-04-2014, 02:15 PM   #11 (permalink)
I wonder why OMGaud doesn't just come out and SAY what his fracking gadgets are?
'Cause he got a deal on a job lot of asterisks and quotation marks, and has to use them up before they expire?
The Following User Says Thank You to jamesqf For This Useful Post:
ecoTex (07-05-2014)
Old 07-04-2014, 02:28 PM   #12 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by counterbond View Post
So I have a neighbor who started seeing this guy who is claiming 60 mpg on a chevy Blazer by hooking a hose to a gas tank in the trunk drawing vapor into the intake of the engine engine which then leans out the injectors conserving fuel. Is this guy blowing smoke up my ass or what. He wants to make one for my Saturn...
60mpg? i'd believe it, assuming fuel, not figured into the mileage, is flowing from the tank in the trunk twice as fast as it comes from the blazers regular tank
assuming the gas tank in the trunk is gasoline, gas vehicles already draw vapors from the tank via the purge valve
Old 07-05-2014, 05:30 AM   #13 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by Gaud29 View Post
Hey , you know what: "Screw" > these people on this site, (with all Due Respect), these people cannot see: "OUT OF THE BOX"! Believe me, I "USE" > Gadgets, and have been getting "clobbered" by these folks, telling me I'm so full of "##it, but of course in other words,, I'm sick of it, I use 2 MAIN gadgets , I've used one since '97, it "WORKS", the other I found back in '05, little success in the 1st one, but the 2nd one WOW! Yes, I 've even bought 2 more, and one was just put onto my '91 Chevy Blazer, (full-size,4wd), and the other is going onto my other Geo Metro,, I'll expect to "BREAK" > 100 Mpg Hwy, on that... they're all "Nay-sayers" here, seems like? They don't want to admit that some things WORK! I'll just bet $, they're too dammed cheap, or "POOR" > to buy, and test these "gadgets", or just too "Ckin**it" to try them! Sincerely, M.Gaud
there is a "subliminal" message here. admitting the truth!
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
Xist (08-16-2014)
Old 07-05-2014, 07:18 AM   #14 (permalink)
You can get 90 MPG in a lot of vehicles, it you only average 20 MPH and engine off P&G.
They did 124 in a 1970 Opel Station Wagon around 1970. Limited throttle travel, 15-45 P&G in 3rd gear, engine off coasting.
The real challenge is doing it so it can not be detected in normal traffic. We have KNOWN HOW to do it for at least 70 years.
People come here to share ideas Gaud, What you're sharing is? Unsupported claims without real unbiased testing. We're supposed to believe everything you say. I remain skeptical, in much the same way you would if I told you something your experience just would not let you follow.
Without real proof?
regards
Mech
ecoTex (07-05-2014)
Old 07-05-2014, 09:36 AM   #15 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
If his "gadgets" are an electric motor, controller and a pile of batteries, 100 mpg might be doable.
Old 07-05-2014, 10:40 AM   #16 (permalink)
Or a tow strap hooked to a vehicle in front.
Old 07-05-2014, 11:27 AM   #17 (permalink)
ecoTex's Avatar
green VX - '95 Honda civic VX
90 day: 59.74 mpg (US)
Or a solar powered unicorn-fart" > generator#
My adjustable WAI / HAI build thread
http://ecomodder.com/forum/showthrea...tml#post408134
Old 07-05-2014, 08:35 PM   #18 (permalink)
mechman600's Avatar
I love how most Unicorn discussions eventually end up with this suggestion.
Old 07-20-2014, 01:38 PM   #19 (permalink)
Actually if you think about it, all modern gasoline fuel systems are vacuum driven gas vapor systems.
The gasoline is exposed to vacuum anywhere between the throttle and the top of the piston, until the valve closes and the air fuel goes into compression. When driving down the road you can expect to run between 15 and 22 inchs of Hg. That's a vacuum of -7 to -10 psi.
Heat in the fuel that gets picked up on its way to the gasoline induction system combined with exposure to the vacuum should flash all the gasoline to vapor in the warm to hot vacuum environment.
Old 07-20-2014, 02:24 PM   #20 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
If that was true, then newer injectors wouldn't be going towards the trend of smaller and higher number of holes (example ev1 vs ev12 injectors). This is true of port and direct injectors for diesel and gas engines. This increases the power per given fuel injected.
The OP's statement for the operation is faulty though, in that the closed loop operation is not responsible, since he implies that the total quantity remains constant. If constant, there is now savings. The explanation I gave would, but I have yet to see it documented correctly. Adding a system like this would also throw the fuel rich/low zones (important for high swirl chambers) off kelter, since the pulsewidth and air mix would be changed.
In short, no proof, and gets too complicated for sweeping generalizations. But, I would be open to hearing a constructive discussion on the matter.
Shooting for 600 miles of range at 65-70 mph out of a vx.
