Old 01-18-2012, 06:28 PM   #11 (permalink)
...beats walking...
...a "new" automotive term would have to be used: a "Hyndenberg Blow-out"
Old 01-18-2012, 06:35 PM   #12 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
old tele,
you've been in the 'altitude' for tooo long.!!!
lol
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-18-2012, 06:59 PM   #13 (permalink)
...beats walking...
...uh, which? 'altitude' or 'attitude' or 'aptitude'? or, all three?
Old 01-18-2012, 07:25 PM   #14 (permalink)
Eco taco - '21 Toyota Tacoma Sr access cab
90 day: 22.72 mpg (US)
H2 is bad in tires. They put n2 in tires so when they warm up or temp changes it doesnt change. H2 changes volume rapidly idk how much but I do know that the difference at night alone would make them go flat.
Old 01-18-2012, 07:27 PM   #15 (permalink)
mcrews's Avatar
you've been in tuson tooo long! the thin air is affecting your tinkin!!!!
inventing new words!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-18-2012, 08:45 PM   #16 (permalink)
...beats walking...
...warped minds are easily amused (I'm told...repeatedly).
Old 01-18-2012, 09:38 PM   #17 (permalink)
You guys are confusing un-sprung weight with un-sprung mass. Most of the time the terms are interchangeable, but even if you somehow achieved negative weight, the mass is what matters.
Anyway, on topic... best places to lose weight on a car:
Wheels
Tires
Brakes
Exhaust
Intake
Battery
Spare Tire/jack/tools
not carry around extra crap
Those are all legal mods in *ST classes, and it's not uncommon for a *ST autocross car to weigh in 150-200lbs below curb weight, without sacrificing any creature comforts.
That said, I wouldn't pursue replacing any parts with lightweight parts until they wear out. For the battery, you can use a Deka battery (much cheaper than the Odyssey, and same manufacturer as Braille) for a significant weight savings when your current battery dies. When your tires go bad, look into some used lightweight wheels at the same time and you can probably save a few pounds per corner. If you are willing to do some non-reversible mods you can save some more weight with strategic cutting.
The Following 2 Users Say Thank You to ProDarwin For This Useful Post:
Ecky (10-28-2014), kurzer (01-19-2012)
Old 01-18-2012, 10:30 PM   #18 (permalink)
...beats walking...
"And, now, back to our regularly scheduled programming."
ProDarwin is correct, especially about exchanging the stock heavy cast-iron 'exhaust' manifold for a set of light-weight tube headers! Not so much, though with 'intakes' as most "current" engines actually are using molded plastic assemblies. But, if it's an older engine, there's a 50-50 chance the intake could be either aluminum or cast-iron.
Old 01-18-2012, 10:43 PM   #19 (permalink)
90 day: 29.78 mpg (US)
Quite right, it was only me getting sloppy with my grammer. Mass would be the correct word since we are interested in the objects inertia, which is not subject to change. Weight on the other hand changes with acceleration.
Old 01-18-2012, 11:54 PM   #20 (permalink)
http://ecomodder.com/forum/showthrea...ies-18547.html
