View Poll Results: What diameter tires you are running on. (choose closest option)
Bigger diameter 5 17.86%
P235/75R15 Diameter = 733 mm = 28.85 inch 1 3.57%
P225/55R17 Diameter = 679 mm = 26,73 inch 1 3.57%
P215/60R16 Diameter = 664 mm = 26,14 inch 1 3.57%
P195/60R15 Diameter = 615 mm = 24,21 inch 4 14.29%
P185/65R14 Diameter = 596 mm = 23,46 inch 7 25.00%
P145/80R14 Diameter = 587 mm = 23,11 inch 3 10.71%
P175/70R13 Diameter = 575 mm = 22,64 inch 4 14.29%
P155/70R13 Diameter = 547 mm = 21,54 inch 1 3.57%
Smaller diameter 1 3.57%
Voters: 28. You may not vote on this poll
Old 09-11-2011, 05:14 PM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
What diameter tires are you using at the moment?
I need some back up data on ecomodders tires when I will go to nokiantyres to talk about some special purpose tires which I will need on my Lupo 3L. I suggest that they would make about 5 different sizes with about 8% diameter steps :/.
You can legally change the diameter of tire 5% to each direction in EU, is it the same in the states?
Oh and the new very low rolling resistance nokian tire is not yet on the market .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-11-2011, 05:23 PM   #2 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
25.5"
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 09-11-2011, 05:26 PM   #3 (permalink)
Driving the TurboWeasel
25" or so, the ones the came on the car OEM. 215/55-17.
2012 Chevrolet Cruze Eco 6MT
Old 09-11-2011, 06:17 PM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
25.07" (P205/50-R17). OEM were P185/60-R15, 23.7" diameter. New tires are 5.31% taller. US mfrs don't recommend going above 3% taller.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 09-11-2011, 06:35 PM   #5 (permalink)
...beats walking...
...OEM on our 2011 Cruze LTZ is P225/45R18 on "flangeless" alloy rims.
Old 09-11-2011, 06:39 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Vekke -
195/65 15, one size up from stock, about 2+% larger diameter and 1 lb heavier than stock. I don't know of a specific law in the USA that prohibits tire size change. It's more a physical thing of fitting in the wheelwell. I could have fit two-sizes up from stock for a 4% larger diameter, but the tire jumped to 3+ lbs heavier.
CarloSW2
American Solar Energy Society
Old 09-11-2011, 07:20 PM   #7 (permalink)
In the US we can do pretty much what ever we want with tire size as long as it with in reason.
On my car I run P225/60R16.
Taller and narrower that the dead (245/45) 16 inch OEM size my car came with.
On the truck I use 31x10.5R15. That is between 2 to 3 inches taller a little wider than what it left the factory with. I went taller for less rotations per mile and wider for the load rating.
Old 09-11-2011, 08:02 PM   #8 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'm running the very popular 205/55/16 24.87 in 631.69 mm diameter
Can't do a range of tyres in Europe without this size.
(As an OEM alternative to the stock 195/65/15 24.98 in 634.49 mm.)
In Belgium, we're limited to - 2 % and + 1,5 % differences in tire diameter.
It definitely needs testing then.
Old 09-11-2011, 09:10 PM   #9 (permalink)
Black RS - '04 Toyota Echo RS
90 day: 45.03 mpg (US)
Dumb question everyone,
has anyone noted a significant gain in MPG's due to lower cruising RPM's with bigger wheels, in spite of possible losses in aerodynamics and gains in weight?
Old 09-11-2011, 11:04 PM   #10 (permalink)
Pishtaco
SentraSE-R's Avatar
Yes. Tall tire test. Note page 1 of that thread shows the heavier, less aerodynamic wheels/tires don't give significantly worse performance than the OEM stockers.
Darrell
