View Poll Results: What PSI are your tires at?
<35 PSI 0 0%
35-40 PSI 22 32.84%
41-45 PSI 19 28.36%
46-50 PSI 11 16.42%
>51 PSI 15 22.39%
Voters: 67. You may not vote on this poll
Old 12-10-2019, 09:00 AM   #71 (permalink)
Joggernot's Avatar
Originally Posted by Plasmajab View Post
Weirdly enough.. My trucks door panel says 35 psi. But I noticed on my last ones that the outer edges on all four tires are worn.. I religiously kept them at 35, but now Im at 40 to see if it makes a difference in tire wear. Regardless of the fuel economy.
I have always run max sidewall pressure in a pickup. If it says 51 psi max, run 51 psi. If it says 80 psi max, run 80 psi. Never had the outer edges or the middle wear faster. YMMV.
Old 12-10-2019, 10:03 AM   #72 (permalink)
It's a 8 ply rated commercial tire that has noticeable tread bulges and sags at different pressures/ loadings. Neither of these arguments have convinced me. When I run mfr recommended pressure the edges wear out first on the front, the centers go on the rears.
Old 01-12-2020, 08:51 PM   #73 (permalink)
40 cold on the Prii, 80 on the Suburban load range Es
Old 01-13-2020, 01:31 AM   #74 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
34PSi to 40PSI front 41PSI rear
5.94% increase in mpg :O
for free
went from 26.9 to 28.5mpg
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
ptjones (01-13-2020)
Old 01-13-2020, 02:02 PM   #75 (permalink)
I was running 50 spi in my 2016 F150 and with 43k miles I had 1/32" less tread in the center so I dropped it to 45 psi. I average around 25 mpg on HWY with 2.7 ECO Boost, 4X4 and 3.55 rear end.
