View Poll Results: What PSI are your tires at?
<35 PSI 0 0%
35-40 PSI 22 32.84%
41-45 PSI 19 28.36%
46-50 PSI 11 16.42%
>51 PSI 15 22.39%
Voters: 67. You may not vote on this poll
Old 12-02-2019, 08:54 PM   #61 (permalink)
shaggin waggin - '12 VW Jetta Sportwagen
Originally Posted by KDulcimer View Post
I'll be honest, I don't see any point in raising tire pressure. Any pressure above what the car manufacturer tells you, and you're simply eating up your tires. You'll save a penny on gas and spend 10 cents on tires.
Run it at stock pressure.
If you want to save a buck on gas, buy it in bulk whenever it's cheap. That has a LOT more to do with your cost per mile for gas than your tire pressure.
Reminds me of an episode from "it's always sunny in Philadelphia" the gang solves the gas crisis, one the more memorable shows in the series.
Old 12-02-2019, 11:13 PM   #62 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
What's a guy doing on here telling people to run low tire pressure? Lol.
In all seriousness, anything under 35 is low/flat.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-03-2019, 06:49 AM   #63 (permalink)
90 day: 56.3 mpg (US)
"Do not modify your car for economy"
Fat Charlie (12-03-2019)
Old 12-03-2019, 02:05 PM   #64 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Cargo capacity aside, the biggest difference between passenger vehicles and big rigs is focus. Work trucks are meant to haul as much stuff as possible as cheaply and reliably as possible, while passenger vehicles are about "image" and a cushy ride.
If I had a long-haul freight truck, I wouldn't second guess the engineers on efficiency. But your average, run of the mill car is a sloppy POS designed to be cute or manly or whatever. Mod the hell out of it.
Transmission type Efficiency
The Following 4 Users Say Thank You to Fat Charlie For This Useful Post:
Ecky (12-03-2019), elhigh (12-05-2019), RedDevil (12-10-2019), Xist (12-05-2019)
Old 12-03-2019, 08:56 PM   #65 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
It is impossible to know just how much engineers sacrifice on cars to limit NVH...
It is interesting to note that out of 60 votes, nobody here inflates their tires under 35 PSI. I'll admit that I used to keep mine at 32 PSI. I have them at 38 now, and it seems better. I would like to experiment with higher pressures when I get new tires since mine are so worn down.
Old 12-04-2019, 09:31 AM   #66 (permalink)
That's because I don't own a jeep or pinto anymore with grossly oversize tires which both ran at 10-15 psi
I cant drive the f250 @ 32, it's flat for all intents and purposes.
Old 12-08-2019, 06:44 PM   #67 (permalink)
70 front 55 rear unloaded in F250, 40 front 36 rear Golf, 45 all 4 in Ranger.
All based on actual 100% tread contact with road.
An unreliable method. The single one accurate is to pressurize to heaviest tire load per axle. See CapriRacer posts and website.
Old 12-09-2019, 09:57 AM   #68 (permalink)
Why is it unreliable other than the limits of the thermal scan accuracy? I axle weighed the F250, this was the result unloaded. When it's loaded the pressures increase on the rear, but not much on the front, the result of weighing the axles loaded.
Old 12-09-2019, 10:45 PM   #69 (permalink)
Dimples - '07 Ford Ranger Sport
90 day: 18.28 mpg (US)
Weirdly enough.. My trucks door panel says 35 psi. But I noticed on my last ones that the outer edges on all four tires are worn.. I religiously kept them at 35, but now Im at 40 to see if it makes a difference in tire wear. Regardless of the fuel economy.
Old 12-10-2019, 08:47 AM   #70 (permalink)
Tire Geek
CapriRacer's Avatar
It's unreliable because it assumes that even loading/even pressure distribution/even wear is what the tire was designed to do. As a tire engineer, I've designed tires to purposely wear unevenly when loaded per the load charts in order to improve rolling resistance.
Second, it is also possible to design a tire that has good contact for a large range of loadings/inflation pressures. In that case, it would be hard to determine what the optimum inflation pressure would be. I certainly would expect a layman to be satisfied long before he actually gets the optimum value.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
Xist (12-10-2019)
