Old 03-25-2010, 01:19 PM   #1 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
What would it take to make a range-extended series hybrid?
I've toyed around with the idea of a DIY series hybrid numerous times, and mentioned it here once or twice. Anyway, what all would a person need to build a range extending plug-in series hybrid? (Not a charge maintaining hybrid like the Volt.)
Use a Metro sized car for the donor car. I'm thinking of a power takeoff generator like this one, mated to a 30 hp or so diesel (or even gasoline tuned for lean-burn) engine through a reduction gearbox. Set and optimize the engine for single speed operation. Couple that gen-set, set at 220V, through a on-board charger. Use a two string 120V battery pack and an ultracapacitor, routed to DC motor/controller. At home charge via 220V single phase. Daily driving ~110 miles/day.
Could such a setup provide decent power and range?
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 03-25-2010, 01:39 PM   #2 (permalink)
How is that different from the Volt?
Old 03-25-2010, 03:09 PM   #3 (permalink)
chuckm's Avatar
The Volt's genset is sized to be a charge-maintaining system. I'm talking about a using genset that is unable to provide average driving load amps.
I don't think charge-maintaining is necessary unless you plan on driving 300+ miles in one shot. I think the better way to go, for most people, is to charge your battery pack from the grid, but decrease the load on the pack with the genset. By providing only some of the required power from a genset, you extend the range of your pack (hence range extending). The Volt will go as long as you have gas in the tank because it will *maintain the charge*.
Old 03-25-2010, 03:55 PM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
VW wagon EV with charging trailer...thoughts?
Old 03-26-2010, 12:18 PM   #5 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Use a heavy duty A-B switch to isolate batteries from controller & to engage the generator to the controller. You can switch over to the generator whenever your heart desires.
Old 03-26-2010, 12:30 PM   #6 (permalink)
I still don't understand. You basically have a volt, but now your engine isn't big enough to recharge the batteries to keep you going at highway speeds?
Old 03-26-2010, 12:41 PM   #7 (permalink)
I believe he sees recharging the batteries with the generator as a poor use of fuel. To maintain highway speeds he would need to make sure that the generator can provide enough electricity.
Old 03-28-2010, 11:00 AM   #8 (permalink)
sprkthead2's Avatar
Zoey - '09 Honda Civic Si
90 day: 34.73 mpg (US)
Subee - '01 Subaru Forester L
90 day: 27.52 mpg (US)
You mean a series hybrid. GM coined the phrase range extender, which is a series hybrid.
Old 03-28-2010, 01:28 PM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
I think there is a difference between those two. A series hybrid is an electric car with a generator engine large enough keep a charge for as long as it has fuel, no matter how you drive. A range extender is an electric car with a small engine which adds some juice to the batteries (or actually slows down their rate of discharge), but not enough to allow any type of drive for an indefinite time. At a slow speed the small genny may barely charge the batts, but the generator will supply only, say, 80% of the power needed to sustain highway speed. The car will have to slow down when the batteries discharge, though this will happen after a distance 5 times greater than without the engine.
I think the undersized genny is better, since it will work great in a typical driving scenerio: drive some, stop, drive some more. The batteries recharge during the stop. Even on the highway you could go 12-15h, with stops every 3-5h for lunch+pee, then sleep while the genny recharges. But a series hybrid isn't the most efficient set-up for highway driving.
Old 03-28-2010, 03:57 PM   #10 (permalink)
sprkthead2's Avatar
No difference, don't fall for the GM marketing scheme. Its a hybrid not electric car. Since it carries an ICE and fuel for the ICE it is a hybrid, a series hybrid at that. An electric car only carries batteries, no ICE.
Hybrid Center :: How Hybrid Cars work :: under the hood 2
powered trailer idea (EV pusher trailer to make conventional car a hybrid) Tango Charlie Hybrids 83 09-07-2020 12:48 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
FVT eVaro plug-in serial hybrid NeilBlanchard Hybrids 52 01-23-2011 06:46 PM
how to make a DIY hybrid 2010 Corolla S? GenX Rolla Hybrids 8 08-22-2009 10:51 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
