Old 07-07-2009, 11:04 AM   #11 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
I think GPS is the most under utilized tool for improving fuel economy. when I plotted all my normal routes I discovered that most of the time I was not going the shortest way. If you drive 7 miles to work every day and can find a route of 6 miles that is about 14% in fuel savings.
If you go to several places use your GPS to plot the most efficient route and order. Not all GPSs do route-planning but a lot do. You can easily save 20 - 25%.
Old 07-07-2009, 11:49 AM   #12 (permalink)
Metro - '98 Chevrolet Metro LSi
90 day: 44.6 mpg (US)
1. Don't drive your car.
2. If you do drive, know your real MPG so you can have a baseline.
3. Keep your car maintained. If you keep up with it, you can use the cheap stuff
4. Remember that your car is only a tool to get your from one place to another.
5. Your tires are important. Keep them rotated, blanaced, inflated & aligned.
6. Coast whenever possible.
7. Turn off the car at railroad tracks and long red lights.
8. Simplify your intake. I've never seen a car that didn't improve FE by removing ducting.
9. Get some instrumentation to keep you honest with yourself.
10. Don't obsess about it. It's important, but not the end of the world.
Trying to make the most of what God has given me.
Old 07-07-2009, 12:10 PM   #13 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
I'm sure you already know this, but "shortest" is not necessarily the most efficient. Here's just one example based on real-world conditions:
Marietta, GA to Lawrenceville, GA: The shortest route is I-75 to I-285 to I-85, at 37 miles. The I-75 to I-85 route is 6 miles longer but takes 30-45 minutes less time in rush hour because you are stuck in traffic only on the section outside I-285, not the whole section of I-285 between I-75 and I-85 plus the section outside I-285.
I also take a route to work in the morning that is five miles longer than my return route, but I use less fuel because I get out early enough to avoid traffic on the highways, whereas the lights on the return route are there 24 hours.
Old 07-14-2009, 08:14 PM   #14 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
The article got published today. It's been reduced to a top 8 by the editor. You can check it out at tdicurious.ca.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 07-14-2009, 09:14 PM   #15 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Nice list, tas. And congrats on getting on the TDI site.
Old 07-14-2009, 09:20 PM   #16 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 27.11 mpg (US)
My top 5
These are my top 5 in order of importance I believe:
Keep track of your MPG
Stop speeding all together
Pump your tires up
LRR tires are great
Coast whenever you can (possibly in neutral)
Old 07-15-2009, 05:23 PM   #17 (permalink)
Thank you. So far it's been a nice experience dealing with them, and I'm looking forward to future projects.
It was initially a top 10. I find it weird they decided to left the driving without brakes and instrumentation parts out.
Old 07-15-2009, 06:07 PM   #18 (permalink)
EcoModding Dilatant
Of course you are right. Distance is not the only factor and long trips with no stops can be more efficient than shorter trips with lots of stops. An infallable rule can't be stated for all situations.
But still, efficiency isn't really the goal - using less fuel is. Driving ten miles at 20 mpg is more efficient than going seven miles at 15 mpg, but the seven mile trip still uses less fuel - and that's the real goal.
We all tend to get hung up on getting the best mileage, but that doesn't always translate into less fuel used.
Old 08-04-2009, 09:47 PM   #19 (permalink)
Certified Duct Tape Tech.
swoody's Avatar
Slow Ride - '00 Honda Civic DX
90 day: 46.32 mpg (US)
You make a good point there instarx. I think I may pay a bit more attention to my total fuel consumed now, and weigh it in against getting the best mileage I can.
~ If you don't jump with both feet, you don't move at all ~
2000 Civic DX :: 52/50 psi :: Free Warmer Air Intake :: Duct Tape Aero
"Spare the duct tape, spoil the job."
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
