Old 07-08-2009, 07:38 PM   #121 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Can't turn them inward, either?
I didn't mean to raise them, I meant to put your arms closer to your core. My buddy's CBR1000's bars are adjustable inward/outward for rider comfort.. never tried that specific mod w/ a Ninja 250, just guessed that it could be done, since it can on other bikes.
Old 07-08-2009, 08:04 PM   #122 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Yup, they are not clipped onto the fork tubes from the factory. There is only one mount and you cant tweak them without buying clip ons.
Still, it hasn't been a problem for me at 6'1", 185lbs.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 08-15-2009, 03:00 AM   #123 (permalink)
The best I've gotten on my XT225 is about 82MPG.
Normally I get 65-70MPG. Some city, some highway.
Old 08-15-2009, 04:30 AM   #124 (permalink)
janvos39's Avatar
jvsgears - '14 Skoda Octavia
Team m8
90 day: 52.47 mpg (US)
Jason if you get 82 what kind of hypermiling tricks are you using?
Old 08-15-2009, 11:12 AM   #125 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I commuted to work for decades on motorcycles. Folllowing are average real-world mpg figures I accumulated/achieved.
1964? Honda Cub 50 step through = 145 mpg
1971 Suzuki TS-90 two stroke trail bike = 90 mpg
1966 Suzuki T-20 X-6 Hustler two stroke = 55 mpg
1970? Suzuki T-500 two stroke = 40 mpg
1978 Suzuki GS-1000 four stroke = 50 mpg
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 09-01-2009, 05:49 PM   #126 (permalink)
College Student
That is a lot of MPG's... pretty impressive. Especially 145... that's just insane
Old 09-09-2009, 06:18 PM   #127 (permalink)
I've had a few older motorbikes over the years, though never pushed to get high mpg's. My first was a 1982 Honda C70 Passport, aftermarket carb and a few other mods. I think I hit about 120mpg once, but it's not a big bike by any stretch.
I had a 1984 Toyota Tercel 4WD wagon that would hit as high as 42mpg in Missouri winters in the mid-90's, but that's as good as it gets for my cages.
My current is a 2007 Ninja 250 with about 27k miles. I've put a tall custom Lexan windscreen on for comfort, a rack with a top case and saddlebags. I've swapped the gears for a 15/41 set from JTSprockets, the tires for Kenda's K657 130/90-16 rear and K671 100/90-16 front. Lots of other little farkles, but it's mostly set up for comfortable commuting. Even so, I hit 81mpg on a fairly straight and somewhat hilly stretch of Hwy 29 North of Austin. I was running about 65mph. Don't remember the temp, but it was spring. I need to strip it down and see what I can max it out at someday...
Old 09-09-2009, 11:09 PM   #128 (permalink)
Nice bike!!!! Good to see a fellow ninja 250 rider on here.
You have pretty much the same bike setup as me, I'm just a little lower on gearing. What shield do you have? One of mikes shields?
Have you messed with the jetting at all?
And enjoying it!
Old 09-10-2009, 01:45 AM   #129 (permalink)
Custom Lexan windscreen. Dremel cut, lower vent to reduce buffeting (really helps, think ST1200/Concours). I made a template on clear Mylar using the stock mounting points, including the mirror mounts. I don't use the two upper stock mounts, it helps keep the screen more upright. More at the link.
Jets are stock.
Old 09-10-2009, 03:15 AM   #130 (permalink)
hello all i'm riding a 600 fazer 2001 commuting 47 motorway miles and am achieving 194 per 11.94 ltrs = 73 mpg. which is around 55-60 mph at just under 5000rpm
most blokes at work laugh at my 'grandad' riding but at 112p per litre can't afford to cane it. It takes me an hour to complete the journey but going 70 - 80 it only knocks off around 10 minutes which isn't worth the fuel.
some blokes at work are actually coming around to the idea of eco riding, most don't even check their tyre pressures regulary.
got a smaller sprocket to fit today 47t so will see what that does.
Motorcycle fuel economy champ's advice for efficient cross-country touring... MetroMPG Motorcycles / Scooters 6 01-31-2008 02:38 AM
