Old 01-30-2015, 02:06 AM   #1 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
Whats your tyre pressure?
im currently running 35psi. but my tyre max press is 51psi. what is the highest I can safely run it. also here temps are very high 30 to 35 deg C (85-90F) and I wil be driving longish distance every day (100miles) so tyres will warm up?
Old 01-30-2015, 03:10 AM   #2 (permalink)
I'd say the highest you can safely run it would be 51 PSI. Even at high temps and with long trips. The hot pressures may be more, but the tire has been tested to be OK when starting out at 51 PSI cold.
I have my tires at 50.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
Eddie25 (02-01-2015)
Old 01-30-2015, 06:05 AM   #3 (permalink)
Focus - '05 Ford Focus tdci Futura
I don.t know what the max tire preasure is. Michelin wont put them on. I also called them to ask for the max sidewall preassure. But all i got was that the max preassure for my paticulair make and model 2.5bar was. I have michelin alpine a3 tires. And i now drive them at 3.2bar.
The Following User Says Thank You to NickelB NL For This Useful Post:
Old 01-30-2015, 06:20 AM   #4 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
65psi inna 44psi maxsidewall tire
The Following User Says Thank You to dirtydave For This Useful Post:
Old 01-30-2015, 07:50 AM   #5 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
48 in a 51psi max tire. I just don't feel comfortable being at the max something is rated at. Plus the road noise is more tolerable.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
Old 01-30-2015, 08:20 AM   #6 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I usually do sidewall max, which is 44PSI for the Prius' current tires.
Anything between the recommended and sidewall max should be safe. I personally would rather be 10PSI over the sidewall max than 10PSI under the recommended.
Camry Thread
E-Bike Thread
The Following 2 Users Say Thank You to vskid3 For This Useful Post:
Eddie25 (02-01-2015), Fat Charlie (01-30-2015)
Old 01-30-2015, 10:28 AM   #7 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Well above sidewall max for years and years.
Eddie25: FYI, a higher pressure will give you a cooler running tire.
Old 01-30-2015, 11:55 AM   #8 (permalink)
I pretty much run 50 psi in all my tires no matter what the sidewall says... Its never been an issue, and I don't have abnormal wear, and I do check.
The Following User Says Thank You to Daox For This Useful Post:
Old 01-30-2015, 12:39 PM   #9 (permalink)
RPM
RPM's Avatar
JF - '97 Honda Civic 1.5i LS VTEC (EK3)
90 day: 59.68 mpg (US)
My tires are rated at 51 psi but I don't go above 36 psi because the ride becomes intolerable. YMMV depending on how well you tolerate a harsh ride, tire compound/construction and wall size. So I say increase it in steps and stop where you feel comfortable.
The Following User Says Thank You to RPM For This Useful Post:
Old 01-30-2015, 01:54 PM   #10 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Hi on my volvo s40 i run 44 front and 41 rear which is 4 psi over volvo pressure. Any more and ride is too harsh on local roads rides very smooth on dual carriage ways and motorways. Also at the moment driving on ice or snow so might be high for these conditions.
The Following User Says Thank You to chefdave For This Useful Post:
