View Poll Results: Why don't you have a MPG readout?
Can't aford one at this time. 22 50.00%
My car is to old. 16 36.36%
I'm not sure where to get one. 5 11.36%
A gadgit isn't going to improve my driving. 1 2.27%
I don't buy stuff off the internets. 0 0%
I didn't realize they were an option! am ordering one right now. 0 0%
Waiting for MPG version of SuperMID 0 0%
Voters: 44. You may not vote on this poll
Old 02-22-2008, 12:05 PM   #21 (permalink)
bestmapman's Avatar
Mount it with double stick foam. It comes right off when your done or want to move it.
Old 02-22-2008, 12:44 PM   #22 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
If there was a cheap ugly version on the market, but worked similarly I would be all over it. With oil at $101 a barrel, the dohicky would pay for itself pretty quickly.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 02-22-2008, 06:18 PM   #23 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
My main reason for not dumping money into an SG is price. My car already has averaging an instantaneous mpg readouts. I just can't justify the large cost of the extra gadget with a small increase in marginal utility.
If I had time, I'd work on a java app make an instrument out of the ODB2-to-DB9 adapter I already have.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 02-22-2008, 06:22 PM   #24 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
What would be involved in that? I might be able to ask my roommate to try that out over spring break?
Old 02-22-2008, 07:00 PM   #25 (permalink)
So here was one simple framework someone made:
http://www.mp3car.com/vbulletin/rr-p...d-ii-plug.html
...but the site (sophonix.com) seems dead now. I might have an old zip of the source files. The "left as an exercise to the reader" is making it a usable instrument...I haven't had time (too busy making web sites for airlines ).
Old 02-23-2008, 01:19 AM   #26 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
its not that my speedo doesnt work, im just redoing the interior (completely) and want to put in my own gauge cluster, the car will definately end up with a dedicated speedo but i was thinking of using the scangauge as a means to get it on the road quicker. i will definately hard wire it or add a second obdII port as i will need the first for my carpc setup
Old 12-28-2008, 10:19 PM   #27 (permalink)
I'd vote but there isn't a scenerio that I'd fit into. I have a 1990 Civic DPFI d15b1. Because it has 2 different fuel injectors that flow at different rates, there is no instumentation that is compatible with this.
I've used fuel rate meters to see what each injector does but I'd prefer MPG instrumentation.
If anyone has any suggestions please let me know!!!!
Old 12-28-2008, 11:09 PM   #28 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I'm pretty sure that the dual fuel injector set up is mostly a "cold start" injector and a "normal" one, the cold start one is used instead of a choke to allow a simpler control set up of the engine, some MPFI systems used a 5th injector like this as well, as seen on older Toyota's.
Old 12-29-2008, 01:26 AM   #29 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Or, assuming both injectors operate at stoich, you could make an instrument that extrapolates MPG based on air flow like the ScanGauge does.
Assumes you're not going into open loop operation, and also it won't factor in cold start enrichment.
Old 12-29-2008, 10:56 AM   #30 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
I voted "car is too old," but I'm in the process of building an MPGuino. Got my new LCD for Christmas, but now I have to work again....
Finally: 100 mpg (US) round trip in the Blackfly - new and improved: 133 mpg MetroMPG Hypermiling / EcoDriver's Ed 12 11-02-2012 05:08 PM
BBC reporter drives the new VW Polo Bluemotion 566 miles, gets 50 mpg (US) MetroMPG General Efficiency Discussion 1 04-08-2011 10:58 AM
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 09:30 PM
Equivalent MPG of cycling - garage feature? MetroMPG Alternative Transportation 21 12-27-2007 01:57 AM
Article: 57 mpg? That's so 20 years ago SVOboy General Efficiency Discussion 17 12-23-2007 09:56 PM
