Originally Posted by Grant-53
The idea is perhaps to evaporate fuel. In a conventional card the evaporation may cause the air/fuel mixture to cool the gas and make it more dense. Take a look at the carbs on a Honda generator. If anyone has the most efficient carb it would be the Japanese. As always: Test Don't Guess.
Yes the 1st video is all about sucking
exhaust heated air through a small cylindrical
air filter, the bottom end of which is submerged in fuel, wicking it up.
(maybe it's an oil filter element)
He says that this works better than a bubbler as a bubbler only evaporates the lighter fractions, leaving a sticky mess.
In the 2nd video he simply
passes the above mixture through a pipe heated by the exhaust.
There is a bit steel rod in the center of the pipe where some sort of Geet magnetic effect is supposed to happen.
I dont know about that but the heat will certainly vapourise any fuel that isn't already.
Partial Oxidation will turn some of it into
Hydrogen and
Carbon Monoxide. (burnable)
But My point is:
When you watch the video the guy really seems genuine..???
I also NB that these Geet type devices just wont go away, so there might just be something to them?
