View Poll Results: Are wide tires better?
Great invention. 6 21.43%
Ok. 4 14.29%
OK for off road and racing. 10 35.71%
Make vehicles more expensive with no benifit. 8 28.57%
Voters: 28. You may not vote on this poll
Old 07-10-2011, 08:37 PM   #31 (permalink)
Originally Posted by diesel_john View Post
I will admit that the choices I gave for the survey are pretty lame. And probably violated every rule in surveyology. I am just tic'd that 13" tires are being phased out.
diesel_john
It is like they are trying to put the biggest flywheels they can on every corner.
A great strategy for killing urban cycle mileage.Potholes eat small wheels like 13".I run 14" steel on my 95 civic.I don't think 13's would be a good choice on the roads here for my use.But I also notice when wheel shopping most choices are for 15" and up.Fewer choices in 14 for my car.So I will stick with the stock steel.
Some of the new cars have good drag numbers...but they come with expensive flywheels at each corner...arrrrggggghhhhh!
Old 07-10-2011, 10:40 PM   #32 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
well they do help with traction, for example my car has 155/70/12\s on it at the moment,
I can get my car slideways very easily (if i want to but i'm a safe driver most the time)
with 175/70/13's i cant get my car sideways no matter how hard i try, i cannot do "skids" and no matter how hard i take a corner the dam things wont lose traction unlike the smaller tyres, so they do help, but i assume that it does get to a point where the difference becomes minimal
Old 07-11-2011, 02:21 AM   #33 (permalink)
Blow stuff up
phunky.buddha's Avatar
S2000 - '03 Honda S2000
90 day: 24.42 mpg (US)
Wider is better... for me. Here's my rationale- more grip = higher cornering speeds = less acceleration after a turn. So far I'm hitting 1.05G sustained on my morning commute. No need to slow down for cloverleafs or really anything else at all. No slowing = no acceleration = more saved gas. Um. Yeah.
Intercrew Auto Salon
Old 07-11-2011, 07:54 PM   #34 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
I wanted 155's. The local dealers wanted me to have 175's. that led me to the bigger conspiracy. the auto manuf. just know you need 4wd because they specd tires that won't go when we really need too.
Old 07-11-2011, 09:10 PM   #35 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Diesel John I had the same problem with my mechanic. At his suggestion I decided to go to tire rack order the 155x13 tires and have him put them on and balance.
I got some winter firestones and really like them It goes like a tractor in the winter. They are quiet. Probably will melt down some this year but I can get a couple of years I will be happy.
Noah Webster, 1787
Old 07-11-2011, 09:10 PM   #36 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by phunky.buddha View Post
Wider is better... for me. Here's my rationale- more grip = higher cornering speeds = less acceleration after a turn. ... Um. Yeah.
Sarcasm noted, clarification offered:
wider tires scrub more when not going in a straight line, and have more aerodynamic and rolling resistance (to a point).
If you start coasting for the corner sooner on narrower tires and take it at something less than 1G, it will more than make up for the scrubbing and hysteresis and constant loss of wider tires.
Old 07-12-2011, 12:33 PM   #37 (permalink)
Blow stuff up
Yup, definitely more aerodynamic and rolling drag. I lost about 5% efficiency with this latest tire change, but to me it was worth it. You assume scrubbing, but I don't really have any understeer to worry about- more grip for me means more braking and higher turning speeds. My primary priority is grip and handling- any gains I can make towards economy are a bonus that I try to achieve later with driving habits and drafting on long trips.
I went from 225/50-16 front and 245/45-16 rear to 255/40-17 all around with a 140 treadwear rating and I absolutely love it.
As far as wider tires being a conspiracy- I think NO. Car manufacturers try to design their cars to hit certain performance/efficiency targets, so they try to size their tire selection accordingly. Usually a larger diameter tire will net efficiency gains in the drivetrain by allowing lower rotation speeds before the wheel, and larger wheels look better for the consumer, plus clear larger brakes for heavier cars with more safety equipment and cargo capacity...
I guess we could all go back to the original Minis with their 10" wheels.
Old 07-12-2011, 03:18 PM   #38 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
... You assume scrubbing, but I don't really have any understeer to worry about- more grip for me means more braking and higher turning speeds. My primary priority is grip and handling- any gains I can make towards economy are a bonus that I try to achieve later with driving habits and drafting on long trips.
Tires "scrub" anytime you turn them, they don't have to be slipping. In fact a sliding tire is actually losing less energy as you are no longer changing the vehicles direction as much. Not that that is a smart way to take corners....
I'm not coasting, I'm shifting slowly.
Old 07-12-2011, 04:02 PM   #39 (permalink)
This is the main reason.
Old 07-12-2011, 04:05 PM   #40 (permalink)
...I guess we could all go back to the original Minis with their 10" wheels.
13" tires certainly cost a lot less than 16" or 17" tires do. Many of the people here are interested in saving money as a top priority. I am too, but I'm not willing to sacrifice good handling for it - which is why I won't buy narrow 80 series tires, no matter what small amount of fuel they supposedly save.
