Old 01-28-2008, 06:47 PM   #1 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Wind car
This is amazing. Man have we gone backwards. Check out the elegance of this car made in 1973. That is what needs to be reinvented for the X prize.
1970s Jim turned his attention to sail design, inventing new rigs for small sailboats that greatly increased their efficiency. When his then teenage son, Douglas, asked him to design an iceboat, Jim dreamed up a vessel of extraordinary beauty and astonishing aeronautical potential that attained speeds 4.3 times the speed of the wind.
"Judge a person by their questions rather than their answers."
Old 01-28-2008, 06:56 PM   #2 (permalink)
90 day: 51.82 mpg (US)
That's amazing. Need to dig up more information...
Old 01-28-2008, 07:45 PM   #3 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
How on earth do you get your vehicle to do faster then the power that is propelling it? I need to do more research on this, very nice post.
Old 01-28-2008, 08:17 PM   #4 (permalink)
Sailing craft "create" their own wind when they start moving.
With proper sail design, trim & a low resistance hull (or chassis), the faster you go, the more apparent wind your sails "see". If you take advantage of the increasing apparent wind speed by trimming the sails (and/or adjusting your heading - because the apparent wind direction also changes), you can just keep creating more apparent wind and more acceleration (up to a point).
An optimized sail, well trimmed, on an optimized low resistance hull (hydrofoil, in this case) can do amazing things... like this:
Old 01-28-2008, 08:37 PM   #5 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The sailboat speed record is 56mph was set is 2005. The iceboat speed record is 143mph set in 1947. The land yacht speed record is 116mpg set in 1999.
aerocivic.com
Old 01-28-2008, 08:42 PM   #6 (permalink)
Needless to say, I'm into sailing. I can't count how many times I've thought it would be great, silly fun to mount a sail on the Blackfly and see what happens.
Old 01-28-2008, 10:14 PM   #7 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
It's all about the angle. You can achieve the highest speeds when the wind is actually coming from right angles to your desired direction of travel. You start out with your sail angled a little bit, acting like a wing sticking straight up. The wind lifts your sail/wing forward. As you gain speed, you trim the sail to keep its angle of attack from becoming neutral to the new "perceived" wind that the sail sees.
I saw this funky car in a 1980's Popular Science. It was on the cover.
Old 01-28-2008, 11:37 PM   #8 (permalink)
Nomadic Chicken
WaxyChicken's Avatar
Does this same technology apply to vehicles with no ambient wind?
EG - car moves forward, 'sails' get wind, car moves faster forward. but if the car holds still it sees there is actually no wind when it is not moving.
Old 01-29-2008, 08:14 AM   #9 (permalink)
Short answer: you need "true" (ambient) wind for this to work.
Old 01-29-2008, 05:36 PM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
the same way that a sail boat can go faster then the wind, and the same way that the tip of a wind turbine can go faster then the speed of sound (was a problem with some exprimental turbines), it works because insted of working as a drage device (cup getting pulled with the wind) it's working as an air foil, simaler to a kite, sail, propeller or wing, they are all air foils.
the book New Electric Vehicle, has a chaptor on an air foil car that is simaler, it has a horse shoe shaped wing.
What exactly is a "K" car? bennelson General Efficiency Discussion 34 11-30-2021 12:43 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Landon's Epic Vlog Thread: living without a car in a car-happy world Peakster DIY / How-to 129 09-16-2009 12:14 AM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
Report on car culture: Canadians driving more; walking, biking less. Suburbia blamed. MetroMPG General Efficiency Discussion 6 01-24-2008 03:55 PM
