Old 10-29-2011, 12:58 PM   #1 (permalink)
windshield
So i am looking into the windshield angle mod listed in the efficiency mods section, and i was wondering what windshield would be the best replacement for a mazda miata to maintain best visibility with the new windshield angle?
if i just kept it stock, i expect i would be seeing 20% less of the road.
Old 10-29-2011, 01:03 PM   #2 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Modifying the windshield for what? You will see very little gain in efficiency by changing it, and it sounds like a galactic pain in the butt if you want it to look and work good. Your efforts would be better spent elsewhere on the car.
The Following 3 Users Say Thank You to ChazInMT For This Useful Post:
Cd (10-30-2011), mcrews (10-29-2011), Ryland (10-30-2011)
Old 10-29-2011, 01:28 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
unless your building a showcar/hotrod.....why would you start at the windshield?
I would look at a body kit to get a lower profile withuot scraficing the ride quality by lowering the suspension.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-29-2011, 02:29 PM   #4 (permalink)
total conversion
its a total conversion project
im harvesting the mazda miata drivetrain/suspesion and building a sandrail style chassis, attaching a body to it. So the amount of work is astronomical and wouldnt be reduced by keeping the old windshield. But i want it to be more aerodynamic, so i need a windshield which is the approximate width of the stock miata but a little bit taller so that the angle can be changed with no ill effects on visibility.
Old 10-29-2011, 02:40 PM   #5 (permalink)
I think a lot of people are going to start posting images of that green teardrop template if you don't clarify that you are doing this so that it "looks" faster and more aerodynamic.
Old 10-29-2011, 02:58 PM   #6 (permalink)
reasons
it doesnt have to look anything
it needs to be more aerodynamic
the stock miata is something like .37 coef of drag
frontal area should be pretty much stock miata though since the width/height are being determined by a lot of the harvested parts, but the aerodynamics can hopefully be improved to be a .25 or so coef of drag.
So to do that i basically need to follow almost all of the aeromods listed on this website, which includes changing the angle the windshield meets the hood at to be less severe of a change. to do that i think i will need a taller windshield.
I was thinking of switching to the toyota prius windshield, which is slightly wider as well so the wheels would end up being slightly recessed which would be ok since then i can cover them with panels without there being a bump.
but im open to other options.
Old 10-29-2011, 04:31 PM   #7 (permalink)
windshield
If you were going to go to all the trouble to re-engineer your windshield you'd want to all the way to something like a GTP windshield,as Venom and McClaren,Mercedes C-111 III,etc. run.These are $ 3,000 windshield and would require massive modifications to the entire cowl area.
My neighbor ditched his Miata ,got a CRX and picked up 12 mpg without lifting a finger.
Old 10-29-2011, 04:35 PM   #8 (permalink)
People still think the hood/windshield junction is the problem
Old 10-29-2011, 10:51 PM   #9 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Have a look here, for some basics on the ideal shape to strive for.
http://ecomodder.com/forum/showthrea...rt-c-9287.html
Yes you'll want to optimize your windshield - but I would think you would want to optimize the entire 3 dimensional shape of the vehicle.
Coast long and prosper.
Old 10-30-2011, 12:15 AM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
But isn't most of the drag from the rear of the vehicle and from the underside, the amount of drag from the shape of the front is such a small percentage it's hardly even worth worrying about if you are ignoring the rest.
