10-22-2020, 11:55 AM
#11 (permalink)
Maybe a wood chunker would fill your needs better than a wood chipper.
They’re fairly easy to make and you already have the tools and knowledge to build one.
More examples here.
https://duckduckgo.com/?q=wood+chunk...%3DZKmy3ScFVNE
Just a suggestion...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
10-22-2020, 01:31 PM
#12 (permalink)
Eco-ventor
Sterling might be cool but I won't hold my breath for any external-combustion engine to become viable again for automobile usage.
For a conventional drive-line they are quite terrible, but maybe as a range extender it doesn't matter that you have to plan ahead to start and stop the engine.
10-22-2020, 02:27 PM
#13 (permalink)
It looks like the wood chunk is turning perfectly sized fire wood in to wood chunks.
Any 2 inches and up is fire wood. Anything down to 1 inch can be fire wood depending on how much twigs are on there.
I'm trying to turn twigs and even leaves that would normally go into a brush pile then be open air burned and turn it into much more compact, easier to move, easier to store, dry out s lot faster and can quickly be loaded into the coal furnace, compared to raw green twigs.
10-23-2020, 12:31 AM
#14 (permalink)
Indeed, they seem to be better for a fixed-speed operation.
07-10-2021, 02:16 AM
#15 (permalink)
I'm going big on wood chips.
I have lots of nuance trees to get rid of, have a lot of dead trees to get rid of too, have to thin out the trees before they kill each other. Better to have 1 strong tree rather than 3 or 4 dead ones.
I'm putting in a pond to water my fuel trees. I have a road that makes a nice water shead that makes the edge of the road swampy when it rains, I want to drain that water away from the road which causes the road to crumble.
I have only put a dent in the tree problem and I already have a nice hill of wood chips.
09-02-2021, 10:23 PM
#16 (permalink)
I'm going to buy a crucible that can fit in my coal furnace so I can cast and make brass. Nice yellow brass is 70% copper and 30% zinc and zinc is almost worthless.
11-13-2021, 11:00 PM
#17 (permalink)
I'm going to experiment with putting my used motor oil on the wood chips and seeing how horrible that is.
11-14-2021, 12:55 AM
#18 (permalink)
How about the crucible? I knew a VW mechanic who dismantled engines and threw the various metals into drums to sell to the recyclers. He saved out the bronze valve guides and melted them down.
11-14-2021, 01:26 AM
#19 (permalink)
I have only burned trash so far in the coal furnace this winter.
11-14-2021, 12:43 PM
#20 (permalink)
Well, it's been said that used motor oil should not come into contact with the skin because it has carcinogenic elements in it.
I doubt one's lungs could handle the oil any better.
