Old 03-19-2023, 12:51 PM   #31 (permalink)
I killed my wood chipper. Broke the fly wheel right off the engine.
Old 03-19-2023, 02:59 PM   #32 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
A real Woodchipper massacre eh?
Old 03-20-2023, 09:52 PM   #33 (permalink)
Any idea why the flywheel broke?
Old 03-20-2023, 11:59 PM   #34 (permalink)
Putting dry sticks in it.
Old 03-21-2023, 08:30 AM   #35 (permalink)
That would be the prima facie version of the failure. I believe cRiPpLe_rOoStEr was inquiring about the actual breakage of the flywheel to crankshaft union.
Old 03-21-2023, 02:39 PM   #36 (permalink)
Sheared a key or something?
Old 03-21-2023, 10:44 PM   #37 (permalink)
The flywheel assembly has been parted from the rest of the crank at the tapershaft nub. I destroyed it pretty good.
Old 03-22-2023, 12:51 AM   #38 (permalink)
Makes me wonder if a belt coupling could prevented such damage.
Old 03-22-2023, 01:33 PM   #39 (permalink)
I bet that's why the "commercial use" wood chipper has a belt drive. The new version is going to be belt driven with a 1.25 inch 4130 steel shafts turned down to a press fit 7/8 keyed shaft. It will have replaceable bearings.
Old 03-24-2023, 12:39 AM   #40 (permalink)
Too bad you most likely can't (legally) get those horizontal-single either Yanmar or Kubota thumpers, which have built-in pulleys in the flywheel. Definitely boat-anchors, but they're indestructible.
biofuel, biomass, coal, furnace, wood
