05-31-2023, 09:17 AM
#51 (permalink)
Spark ignited throttled gas engine yes leaning makes the EGT hotter
FYI: In a diesel, you just keep adding fuel until you melt the piston tops or throw a rod through the side of the crankcase. Hence my comment about being diesel mechanics
05-31-2023, 09:01 PM
#52 (permalink)
Of course. Yet sometimes adding some alcohol or gaseous fuel instead of just more Diesel fuel may lead to a cooler combustion. And more homogeneous, as the volatility of alcohols and gaseous fuels lead to a quicker flame spread.
06-28-2023, 11:58 AM
#53 (permalink)
The wood chipper is a microcosm of renewable energy.
I take a 400lb machine made mostly of steel with some aluminum, powered by gasoline lubricated with motor oil and grease to make use of "renewable energy".
07-01-2023, 02:54 AM
#54 (permalink)
Would be quite tempting to make some experiences with wood gas as a fuel... And maybe pork grease for lube?
07-01-2023, 12:01 PM
#55 (permalink)
I have to use anti-wear grease or I'll be going through bearing left and right.
Not using AW grease can cut bearing life down to 1% or less than what's normal with anti wear grease.
07-01-2023, 04:06 PM
#56 (permalink)
duckduckgo.com/?q=anti-wear+grease&ia=web
No consensus on the first page of search results. Maybe bacon grease infused with homemade graphene flakes is as good as anything?
.tragectory: Line goes down and to the right.
07-02-2023, 12:24 AM
#57 (permalink)
I think I saw a video called something like "making graphene without dieing". Is it safe?
Any idea if it's better than ZDDP?
07-02-2023, 09:48 AM
#58 (permalink)
You're not running black/ blue green high temperature binder moly disulfide?
07-02-2023, 12:21 PM
#59 (permalink)
I have been using majestic jt-6 only because someone dropped several tubes of it off their trailer. It's a high speed high temp lithium complex grease.
07-02-2023, 12:50 PM
#60 (permalink)
That would be Tech Ingredients. They used high voltage electricity IIRC. I'd much prefer Robt. Murray-Smith's. He uses a blender, whey protein as a surfactant and 10-20 micron graphite powder.
See also #1934-1935 and 1948. He can print graphene on Capton tape with a laser.
