Old 07-31-2023, 01:00 AM   #71 (permalink)
In the oil and gas industry they use an ethylene glycol drying tower and that seems to take care of virtually all of the nastys.
I don't know what is used to clean raw biogas in my country, but I remember reading about "washing towers" which removed those corrosive compounds, and residual COČ too.
oil pan 4 (08-16-2023)
Old 08-16-2023, 11:42 AM   #72 (permalink)
4 ball test
A lube with no EP addtives would fail spectacularly.
freebeard (08-16-2023)
Old 08-16-2023, 01:57 PM   #73 (permalink)
Behold the power of the tetrahedron.
Old 08-29-2023, 10:18 PM   #74 (permalink)
Next wood chipper experiment completed.
And that was, would the wood chipper benefit from an oil cooler?
So I installed a mechanical temperature gauge and ran it twice. The oil temperature stayed between 150 and 160f.
The wood chipper usually doesn't run at full speed and spends a fair bit of time unloaded or lighty loaded.
Old 08-29-2023, 10:25 PM   #75 (permalink)
Maybe it wouldn't actually need an oil cooler. What about its oil filter?
Old 08-30-2023, 10:07 AM   #76 (permalink)
On page 7 near the bottom I added an oil filter that bleeds off some oil line pressure through a 10 micron hydraulic filter and back to the crank case. It filters all of the engine oil about once a minute.
Old 08-30-2023, 04:32 PM   #77 (permalink)
Well, an "oversized" oil filter also often provides a mild oil cooling somehow.
Old 08-30-2023, 05:07 PM   #78 (permalink)
Well now that you mention it I guess the oil filter does increase surface area that the oil comes in contact with quite a bit. I should run it, close the oil filter valve for a little while open it and see if I get significantly hotter oil to the gauge all.
Old 09-02-2023, 02:31 PM   #79 (permalink)
It does, plus it often increases the total oil capacity of the system, so there is a higher mass to absorb and conduct heat away.
biofuel, biomass, coal, furnace, wood
