12-24-2016, 05:44 PM
#31 (permalink)
Originally Posted by Fingie
Just found out a "problem"
The car must be model year 1987 or be older... :/
At least you can still get a wood gas setup into a car there. Here in Brazil only a handful of older vehicles that were converted a long time ago are still granted the right to use a wood gas generator. Anyway, would there be any loophole such as mounting the wood gas generator to a trailer allow you to use it into any newer vehicle there in Finland?
12-24-2016, 06:58 PM
#32 (permalink)
Just found out a "problem"...The car must be model year 1987 or be older... :/
Challenge accepted?
12-25-2016, 07:17 AM
#33 (permalink)
Volvo-driving MachYeen
It's not the generator itself, that makes the system "illegal"
Cars 87- and newer here have to comply with emissions, (Which isn't also a problem itself, syngas burns cleanly)
The problem is that here in eyes of the legislation (not sure if it's EU or our own law)
Wood gas isn't an accepted/certified fuel for roadway use.
But I se a crapton of interesting cars I could run on wood gas.
And the wood gas is produced on-demand, so ecomodding is still something I would do a lot
reducing consumption is still a important thing, so you can drive further on a X amount of wood, even if it's about 75-80% cheaper fuel than gasoline
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
12-25-2016, 09:41 AM
#34 (permalink)
Could you use wood gas for diesel intake fumigation?
Only because when the wood gad runs out you can keep going.
But as far as I am aware no one has tried it in this application.
12-25-2016, 10:35 AM
#35 (permalink)
this application exists, but you need the diesel to ignite the mix. 20% must be diesel.
Diesel engines also have a pinchy tax here
12-25-2016, 10:38 AM
#36 (permalink)
Pure wood w/option to run on gasoline would be better, I think.
12-25-2016, 04:01 PM
#37 (permalink)
Out-of-pocket isn't the only cost. There's also fuel management. What do you think about the convenience of split wood, kindling, pellets, or sawdust?
12-26-2016, 01:30 PM
#38 (permalink)
Split wood is something I can buy from family and friends, (a big plus) but it takes space and has less energy per cubic meter .
It also needs further chopping into smaller pieces, about the size of a half banana (bad example, I know
Kindling is something used in larger fuel applications (heat power plants, etc)
this is also a cheap alternative. don't know the price, though.
Pellets are a common energy source here, but it's a bit more expensive. But it has a great energy content and takes less room.
Sawdust is also an option, but it's a bit too light. The fire can spread easier through the combustion zone, and into the fuel, burning where it shouldn't.
12-26-2016, 02:23 PM
#39 (permalink)
Did you see the top gear where Clarkson drove a wood gasification powered car with spent coffee grinds?
12-26-2016, 05:21 PM
#40 (permalink)
i don't recall- sounds cool, though.
