Old 05-29-2012, 01:18 PM   #41 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by RobertSmalls View Post
Xringer,
I'd like to know how much of my commute I could do on electricity with a Prius C. If you start with a full charge, how far can you get around town without engaging the gas engine? Rigging up a grid charger should be fairly easy, and developing an engine inhibitor should be possible.
RobertSmalls
The main purpose of the engine inhibitor would be to get the car to move while cold, otherwise I see it moot since you just shift to N and the motor instantly kills.
What I have always wondered is if you try to fully charge the battery does the motor start spinning even with everything else off or does it do so once you start to go?
If after you start to move I think that would be fine, just floor it motor and EV would quickly heat and burn off the charge above 80% and your warmup might be less painfull.
Also driving like a snail with no brakes through town (a rarely traveled set of side streets) I was able to go over a mile on EV (remember I didn't select it, the car did for me) but I was averaging probably 12-15mph in that stretch.
Old 05-30-2012, 08:24 PM   #42 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
How much drag will I get,
if I leave that little (triangle) window in the back open, on the highway?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 05-30-2012, 08:43 PM   #43 (permalink)
Slasher's Avatar
Ouch... a broken window? How'd that happen?
Doesn't look like fun...
Old 05-31-2012, 08:12 AM   #44 (permalink)
Highway is not where the C shines (not that its bad, just nowhere near your Insight). Wayne said that you're only getting about 60 mpg at 55 mph and it starts tanking once you get up to 65 mph. At 75 I wouldn't be surprised if you were down in the 40s. Its just not aerodynamic enough, and its geared higher than a liftback.
Well I woke up late from my girlfriend's house today, but the good news was I was able to do a real world test of how the prius c does at speed. you can sort of see from the blurry picture that I drove 40 miles at an average speed of 70 mph and was able to get 50.2 mpg. This was on a stretch of 95 between delaware and baltimore....rolling hills the whole time. 50.2 isn't amazing I guess, but I wasn't doing anything to save fuel. I was stepping on the gas to get to work on time. the other thing to note is that I was slowly gaining mpg the whole time. At 30 miles into the trip I was at around 46 mpg. I was driving between 65-80 mph and was continuing to gain mpg the whole time. Not sure where it would have peaked at but I hit a traffic jam before I could find out
Old 05-31-2012, 08:33 AM   #45 (permalink)
Amazin!
"the Prius c’s EPA-estimated fuel economy ratings of 53/46 mpg city/highway are the highest of all small hybrids, and the 53 mpg city rating is the highest rating for any vehicle without a plug."
Well, that beats the EPA highway 46 MPG number, and then some! Since a lot of folks aren't going to be driving an average of 70 MPH..
Seems like you might be able to do a lot better if you made that trip under the speed limit..
Next time, get up early and set the cruise control to 55..
I see it was warm, did you use the AC at all? And, were you in Eco mode?
Cheers,
Rich
Old 05-31-2012, 08:42 AM   #46 (permalink)
I did a double take when I saw that picture. For some reason, the glass was invisible at that angle.. Phantom Glass!
Cheers,
Rich
Old 05-31-2012, 08:44 AM   #47 (permalink)
yeah, i've done the trip under the speed limit and had much better mpg.. I was just surprised that I still got 50 with the speed I was doing.
I had the ac set to 72, wasn't really doing that much, and yeah I was in Eco mode.
Old 05-31-2012, 09:16 AM   #48 (permalink)
Since the cd of the 'c' isn't up to normal Pirus standards, it must still be pretty good.
70MPH ave and O% EV, tells us that ICE and the Aero isn't all that bad!!
Cheers,
Rich
Old 06-01-2012, 09:36 AM   #49 (permalink)
Did a fill-up to and got Fuelly..
At 318 miles, it needed 5.5 gallons, giving 57.8 MPG (if the dealer gave us a good fill-up).
The odometer display shows 64.3 MPG. Close to an 11% error..?.
We'll see how close it is, after the 400+ road trip this weekend.
That's going to be 97% highway at 65 ish.. I hope, since I'm not going..
Cheers,
Rich
Old 06-01-2012, 10:46 AM   #50 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
The odometer display shows 64.3 MPG. Close to an 11% error..?. (
I would wait for another tank or two before assuming the computer is that far off. If the previous tank was a half gallon short, that would put the mileages pretty close to each other. I would say that that is within the range of a dealer saying it was "full enough".
Camry Thread
E-Bike Thread
