12-04-2022, 02:02 AM
#2481 (permalink)
aero guerrilla
I have investigated tires for delivery vans, as they seem to be the only ones with sidewall height 80, and not 65-40 of passenger tires.
12-05-2022, 09:37 PM
#2482 (permalink)
tinker
lt tires have more reinforced sidewall with more plies and/or usually use bias structure. probably offsets the weight savings you would get from going to a passenger tire.
12-20-2022, 02:11 PM
#2483 (permalink)
YKYAEM when you immediately understand everything about this:
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following 4 Users Say Thank You to orange4boy For This Useful Post:
12-21-2022, 02:10 PM
#2484 (permalink)
Focused on MPG
YKYAEM when a rock in the engine mount causes engine vibrations reminding me to keep engine RPMs under a certain amount!!!
Staying Focus'd on MPG
The Following 2 Users Say Thank You to ECO-AKJ For This Useful Post:
05-24-2023, 09:17 PM
#2485 (permalink)
You know you drive a gen-1 Prius when you are happy to be the first in line at a stoplight, so you can punch the accelerator off the line, simultaneously surprising the driver next to you (and the one behind you) with instant torque, AND building up a cold reserve in the A/C evaporator, so you can have a nice EV mode glide.
Also, you turn off the A/C at stops so the engine doesn't have to run for the sole purpose of replenishing the cold reserve in the evaporator.
(No electric AC on the Gen 1, just a "cold-storage" evaporator)
The Following User Says Thank You to The_Techie_Stirlingite For This Useful Post:
08-04-2023, 05:43 AM
#2486 (permalink)
YKYAEM when you spot a bird dropping on one of the side windows while driving, and your first reaction is:
"Yuck! That will hurt aero efficiency..."
08-04-2023, 03:41 PM
#2487 (permalink)
You know you're a cheap miser when you realize there is no such thing as "mid-grade" fuel and you pump premium and regular into your tank separately to save money. You know how much fuel the tank can take because YKYAEM when you keep track of things like that.
09-06-2023, 10:07 AM
#2488 (permalink)
none - '23 Ford Maverick XLT
When you spend $100 on an aerodynamic improvement that will yield only $90 worth of gas savings in 10 years of driving.
When you think, they should put a V-6 in a corvette and wonder what kind of MPG you could get out of that.
When you wonder what kind of MPG you would get if you installed 4 emergency spare tires.
The Following User Says Thank You to wax87 For This Useful Post:
09-06-2023, 12:21 PM
#2489 (permalink)
What's that in your avatar?
.tragectory: Line goes down and to the right.
09-06-2023, 06:55 PM
#2490 (permalink)
It is my idea for a camper shell once I get my Ford Maverick. It is something I dreamed up and then put to Paint
