12-18-2020, 11:51 AM
#101 (permalink)
Air curtain installation update
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
12-18-2020, 11:54 AM
#102 (permalink)
curtain
Really impressive fabrication! Nice goin'.
05-10-2021, 08:47 PM
#103 (permalink)
Can you guess which video has the air curtain ? Left or Right ?
05-10-2021, 09:16 PM
#104 (permalink)
There is another active thread on here?! Someone is still ecomodding?!
05-10-2021, 09:42 PM
#105 (permalink)
I have been away for 6 months, but I try to ecomod whenever I get a chance !
05-10-2021, 10:18 PM
#106 (permalink)
I can’t see any major difference. Is any air flowing through the duct?
05-10-2021, 10:29 PM
#107 (permalink)
Indeed, not much difference. I believe the angle of incidence of the exhaust might play a bigger role than expected, thus negating any improvement. I will look into it.
Just so you know, the Left video has the air curtain inlet open.
05-11-2021, 12:56 AM
#108 (permalink)
I think it is quite likely that there would be no airflow into that inlet. Measuring pressures at each of the duct would quickly show how much airflow would be occurring.
05-11-2021, 07:32 AM
#109 (permalink)
Long time lurker
I would be inclined to agree with Julian here, but you could also tuft test the inlet instead of pressure tests. Pressure testing is better but not essential
It is possible, though unlikely that you could be getting reversed flow.
05-11-2021, 05:46 PM
#110 (permalink)
Tuft testing will tell you airflow direction, but pressure testing will tell you airflow amount. Pressure testing will also tell you the results of small changes, eg I'd guess that adding a vertical forward projection to the outside edge of the opening would increase the pressure at the mouth of the duct.
