Old 10-02-2008, 07:58 PM   #1 (permalink)
Actuated clutch when gas off
I was thinking today about how much a pain in the but it is to EOC in my car. Kill engine... depress clutch.... shift into nuetral .... bump start engine... repeat.... defiantly a lot of work. I was thinking that a actuator designed to depress the clutch when there is no pressure on the throttle. So instead I would let the throttle out and the clutch would activate. I then would shut down the engine. Coasting with the engine off clutch out. then when I want to "bump start it" I would just depress the throttle a little bit and actuator would release starting the engine. Of course It would have a switch to turn it off when not in use, and would take some getting use to but it would make both P&G and EOC much easier. Any thoughts. What would be some problems with this setup. Any thoughts appreciated.
Old 10-02-2008, 08:45 PM   #2 (permalink)
Red
Red's Avatar
What kind of car? On the KISS concept it would just be easier to use one's foot...
Old 10-02-2008, 11:02 PM   #3 (permalink)
fanamingo's Avatar
It seems like it could be convenient most of the time, but could also be a safety hazard. Wouldn't this disable engine braking on downhills? Even with a disable switch, I wouldn't feel comfortable with it. It could also be a nuisance if you're feathering the gas and let up more than you intend. This would just require a simple rev match to fix, but could be an unwelcomed side effect. Creative idea though!
Old 10-03-2008, 01:49 AM   #4 (permalink)
Send a message via MSN to markweatherill
Hypermiling with labour-saving? I am not sure but why not fit a switch to your clutch pedal that cuts ignition power, and hence the engine, when you dip the clutch and reconnects it as you raise the clutch to bump-start?
Old 10-03-2008, 02:37 AM   #5 (permalink)
hmmm.... all good points. I really don't like to drive around while holding the clutch. I rarely engine break, I coast as much as possible in neutral, and just use the regular break if I have to. I drive a 1986 VW diesel.
Old 10-03-2008, 10:32 AM   #6 (permalink)
I shift to neutral during my glides 95% of the time.
Old 10-03-2008, 03:53 PM   #7 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Try shifting into neutral without using the clutch, it has always worked on all my cars.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 10-03-2008, 05:23 PM   #8 (permalink)
Although I've never driven either, I understand the old Saabs and the VW Lupo 1L (Diesel) had a one-way clutch mechanism that the driver could selectively engage, that sounds to me like your solution. Since you drive a VW, I wounder if a Lupo transaxle could be sourced and retrofitted to your '86 vw
When engaged, it acted like a bicycle's freewheel. A buddy of mine put quite a few miles on Saab's version, he said it took some getting used to in commuting the backroads of Conecticut.
Old 10-04-2008, 12:32 AM   #9 (permalink)
I would love to get a 1 liter lupo setup. Unfortunately there really rare and hard to find. Believe me I looked into it. My car does pop into neutral with out the clutch. Some sort of one action process would be great though. Remove my foot from the gas and I'm free wheeling, press a little on the gas and my car bump starts. Maybe even have a fuel cut off hooked to the break so that when I tap the break the engine turns off.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Same Gas Station - Same Gas Pump - Better FE ??? BlackDeuceCoupe General Efficiency Discussion 14 10-22-2008 03:03 PM
Am I hurting my clutch when I downshift without revving up? KJSatz Hypermiling / EcoDriver's Ed 17 08-14-2008 11:40 AM
