06-10-2015, 10:16 PM
#11 (permalink)
Nice! I should have installed brackets or something--I doubt that mine stays straight!
06-11-2015, 02:24 AM
#12 (permalink)
Lean Burn Cruiser!
If it is lawn edging, then it is a big NOPE! I could tell that the front of my air dam was getting pushed back while cruising. When I would arrive at my destination, the air dam would be shaped like this!
l
l
^if this makes the slightest sense ![Embarrassment](/forum/images/smilies/redface.gif) ^
The Following User Says Thank You to BabyDiesel For This Useful Post:
06-11-2015, 08:33 AM
#13 (permalink)
Originally Posted by MetroMPG
Mr Daox: can you do me a flavour and measure the overall width of your fancy new air dam?
And by that you mean the length of the lawn edging?
06-11-2015, 10:45 AM
#14 (permalink)
Well, sure. The long measurement from wheel arch to wheel arch. I want to measure the edging I have left over from the Civic. And the Flea is currently sitting in Montreal, so I can't check that.
07-06-2015, 10:40 PM
#15 (permalink)
inspired me
5 inches of clearance on this one, vs. 6 on yours. I guess the edging is taller.
I'll dab black paint on the screw heads (stainless).
07-06-2015, 11:59 PM
#16 (permalink)
I wonder if the angle of the "air dam" would make any difference. I've noticed almost all air dams seem to be 90 degrees. I wonder how a 45 degree angle (in either direction) would perform.
See crude attached image. I spent a total of about thirty seconds on the image lol.
07-07-2015, 12:01 AM
#17 (permalink)
Metro, is that your first air dam on Blackfly?
The, I imagine that if you angle the air dam as you mention, first of all, it wold be difficult to shape, but I believe that even if it were 40% longer, so that it extended as low as a vertical one, it would just have air squeezing past it, instead of pushing it away from the dirty undercarriage.
07-07-2015, 08:25 AM
#18 (permalink)
Looks great Darin! How did you attach yours?
07-07-2015, 11:22 AM
#19 (permalink)
flat vs. angled dam
Amateur ramblings:
1) Each would affect front end lift differently. The sticky-outy one (top) would probably reduce front lift more than the bottom one.
2) Those variations might raise or lower the stagnation point compared to a flat dam. I'm under the impression that the lower the stagnation point, the better. (My guess: the top, sticky-outy version is probably best.)
3) You'd hit the top one on far more grade changes, bumps & curbs than the bottom one (assuming same ground clearance).
4) As mentioned, a flat dam is far easier to DIY -- the front-to-side transition is a simple curve.
07-07-2015, 11:27 AM
#20 (permalink)
I didn't use brackets, because I wanted to support the shape of the dam over a wider area. So I cut a 1x3 strip of wood to match the curve of the bumper cover and then attached it to the bottom of the bumper. Then I screwed the edging into the 1x3. I'll post more details & pics when I update my air dam thread.
UPDATED: See post #89 in my original air dam thread for details.
Nope! First was a cardboard prototype made years ago that was only on the car for a short while. Check earlier in this thread - I posted a pic & link.
If your question is meant to imply I don't get things done in a timely matter... I'll answer that later!
