Old 12-04-2009, 05:48 PM   #51 (permalink)
Driving the TurboWeasel
Interesting! Also, bio-diesel is a marvelous cleaner.
Hmm, this would be a fun experiment to do on a lawnmower, then on a slightly larger gravity-fed direct-injection engine.
To the OP: I'm awaiting your results! Keep up the good work!
2012 Chevrolet Cruze Eco 6MT
Old 12-04-2009, 05:58 PM   #52 (permalink)
I haven't really played with adding diesel to a gasser, except for a few rare occasions of putting in a dab for "top end lube".
I have the impression from reading things like Smokey Yunick's work that anything oily in the combustion chamber promotes detonation. I have nothing to go on except the knowledge that diesel is oily, but I wonder if too high a diesel content in a diesel/gas blend would leave oily deposits behind? My thinking is the gassers don't have that nice super high compression and that nice super atomized in-cylinder injector, so the diesel might not combust as completely.
Were I to try it, I think I'd be watching the exhaust pipe, and periodically pulling spark plugs to see if things are getting dirty. Then I'd back off on the diesel or stop.
Which brings me to another guess; lawnmower engines- at least the old side-valve stuff I'm familiar with- have much lower compression than autos so I don't know how much knowledge would transfer over.
By all means play with it, though! There may be a benefit. Who knows, I haven't researched it at all.
Old 12-04-2009, 06:00 PM   #53 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I've read that diesel is in the 15-25 octane range. Low grade D2 has an higher octane number. So if you fill 15% with D2 that would be say 25 octane, and 85% Premium at 97 octane, you get a net blend a tad over 86 octane. I'd be willing to try 15% diesel in my Elantra next summer. Not on a regular basis, but just to see how it works out. You could even safely run higher blends provided you keep your foot off the pedal a bit.
Bio Diesel has a very high cetane number, that would make knock matters worse.
That's right Frank. That's why if I would try it I'd crank the WAI as high as I can and keep the revs low to give the diesel fuel as much chance as possible.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 12-04-2009, 07:06 PM   #54 (permalink)
darcane's Avatar
Originally Posted by Old Tele man View Post
...octane is a figure of merit of the gasolines' resistance to detonation during compression buildup...diesel doesn't have this problem.
...cetane is a figure of merit of diesels' ignition delay, ie: burning-rate under compression.
When you state "diesel" it helps to know if you are referring to diesel fuel or the Diesel engine cycle. Diesel fuel used in an Otto cycle engine certainly does have the problem of detonation and the octane rating is entirely relevant.
Octane is the rating of a fuel's resistance to detonation during compression. It is NOT strictly measuring gasoline.
Same with cetane. It isn't just for diesel fuel, it is for any fuel. And you should know the cetane rating of any fuel you put in a Diesel cycle engine.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 12-05-2009, 11:01 AM   #55 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
So ANYONE willing to test this out?
Buller.... buller...
Old 12-05-2009, 11:22 AM   #56 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
There have been a couple eventual volunteers, and once I get the verdict on whether my Van is going to be totaled by the insurance company or not, I'll throw some fuel in my fuel.
I've put alot worse stuff in my fuel tank, a little diesel ain't gonna hurt nothin'.
Old 12-05-2009, 11:31 AM   #57 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I was going to try some in my work truck but I need to concentrate on my Hoonda fo now.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-05-2009, 11:36 AM   #58 (permalink)
I should clarify - I"ll put diesel fuel in the gasoline tank of my Van before I pull it off the road and convert it to run on the OM616.
Old 12-06-2009, 04:25 AM   #59 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.7 mpg (US)
Well, I'm game. Not this winter though, but in the spring when temperatures start rising.
The nice part about the Ninja is that the tank is EXACTLY (within 0.05 gallons) 4 gallons when it sputters out and you have to switch the petcock to reserve. Also, high-compression! 12.5:1
A thought occurs, however. I've heard that diesel is 7lbs/gal, while gas is 6lbs/gal. Would the 2 differently weighted liquids stay mixed for any duration in a gravity-feeding tank? I figure in a looped FI system, the fuel pump will mix the two while it pumps, but I don't have that benefit in the Ninja. Thoughts on this?
Old 12-06-2009, 11:23 AM   #60 (permalink)
They're of differing viscosity, as well. Good question. I guess I'll have to get a glass jar and put equal amounts of both fuels in it and see if they stratify.
Hmm.. if fuel/water emulsion is good, and fuel/gas mix is good, is fuel/gas/water emulsion even better? We may never know...
PS - You're really going to try it on the Ninja? Don't get me wrong, I don't think it's a bad idea, but I just didn't see anyone wanting to try this on an exotic-type engine.
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 04:24 PM
Gasoline expected to remain cheap this summer Frank Lee The Lounge 0 04-14-2009 03:43 PM
Adding Acetone as an additive to gasoline - worthwhile? havok95z71 General Efficiency Discussion 14 01-18-2009 11:29 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
News: Shell rationing gasoline, diesel in Western Canada AndrewJ The Lounge 4 02-14-2008 08:26 PM
