Old 06-28-2011, 02:45 AM   #1 (permalink)
Knight - '07 Chevy Cobalt LS
Chevyteg - '95 Acura Integra LS
Adding a hood scoop?
Would adding a hood scoop with the opening facing the windshield cause a significant decrease in MPG's? I have a 1995 acura integra that gets a pretty hot engine and wanted to add a scoop but not if it's gonna severely hurt my fuel economy.
Old 06-28-2011, 08:40 AM   #2 (permalink)
None - '97 Honda civic DX
90 day: 36.73 mpg (US)
There is probably an issue with the cooling system that should be dealt with first. Adding a hoodscoop would just be a bandaid.
Old 06-28-2011, 09:22 AM   #3 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
agreed, might be better to get a coolant fush, or find out what's causing the high heat condition
Old 06-28-2011, 09:54 AM   #4 (permalink)
3gd16's Avatar
Wagon - '93 Honda Accord Accord Ex Wagon
90 day: 25.41 mpg (US)
Does it get higher then have way on the temp gauge?
Old 06-29-2011, 03:15 PM   #5 (permalink)
No over heating issues. It just gets hot thats all. And I was planning to block off the front of the car for better aerodynamics but if a hood scoop hurts that then there isn't a point. Could I just get answers on the hood scoop question, not the car over heating question please.
Old 06-29-2011, 03:50 PM   #6 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
In theory, I would think it would hurt your FE, as it would create a lower pressure going into your intake (because it's in a wake) Now, how much it would hurt I don't know. I've wondered myself about the benefits/drawbacks of a forward-facing hood scoop--it'll probably hurt aero but the ram air should help the engine. A rear-ward facing hood scoop would basically give you negative ram air I would think.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 06-29-2011, 05:13 PM   #7 (permalink)
Twuck - '06 Ford F-150
90 day: 17.82 mpg (US)
Rudolph - '95 BMW R1100 GS
90 day: 35.37 mpg (US)
Terrifying - '02 Chevrolet Corvette Coupe
90 day: 28.4 mpg (US)
Big Red - '13 Ford F-150 XLT
90 day: 18.96 mpg (US)
Cowl induction
Look up "cowl induction". There is a high-pressure area at the base of the hood on most cars (AFAIK); a hood scoop facing rearward at the rear of the hood will take in air from that high pressure.
I have no idea how it will affect the aerodynamics of the vehicle, compared to a forward-facing scoop on the front of the hood or no scoop at all.
Old 06-29-2011, 05:34 PM   #8 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Check your coolant/radiator thermostat. I had to replace mine last year. It was stuck halfway open, leading to long warmups and then running hot once it was warmed up.
Old 06-29-2011, 06:25 PM   #9 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
get some exhaust header wrap and wrap your exhaust. That will reduce under the hood temps a little.
Old 06-29-2011, 10:57 PM   #10 (permalink)
Yes I'm aware of cowl induction but most of those are for performance. I just want a little cooler air into the engine. The air wouldn't even hit near the intake at all more like the top of the block. I would just like to know if or how bad it would mess up the aerodynamics.
