Old 08-25-2010, 02:22 PM   #51 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
Originally Posted by Weather Spotter View Post
with out the tubing on the edges they do act like cymbals. with it I do not hear them.
I will have to look into the farings, I need to see a pic to understand what to make.
This sounds like a similar version of the snap-in racing disk problem. The little teeth would scritch-scritch-scritch against the flexing steel wheel. If you let it get to you it could drive you nuts.
CarloSW2
American Solar Energy Society
Old 08-25-2010, 02:25 PM   #52 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by cfg83 View Post
Weather Spotter -
This sounds like a similar version of the snap-in racng disk problem. The little teeth would scritch-scritch-scritch against the flexing steel wheel. If you let it get to you it could drive you nuts.
CarloSW2
that is why I put the tubing on (only one wheel so far, I ran out of tubing). with tubing it goes away!
Old 08-25-2010, 09:47 PM   #53 (permalink)
Wiki Mod
Update:
I got the tubing on all the other wheels, I will test it out tomorrow.
The tubing cost $1.25 a wheel (to go around the whole edge) total cost per wheel: $4.50 counting paint and clear coat.
not bad for a 1.5 MPG gain!
Old 08-26-2010, 03:12 PM   #54 (permalink)
Wiki Mod
I did some driving today, no pizza pan noise!
Old 09-19-2010, 10:24 PM   #55 (permalink)
Wiki Mod
Tubing update:
They stayed on for about 200 miles before the hot glue started loosing adhesion. One back tube came off going over the Mackinaw Bridge (made a thump thump...) I took it off and the pan did not make much noise, some but not bad. I lost 2 more tubes from the edges of the pans yesterday. So they lasted about 1000 miles.
I took the pans off and washed them and the tubes, let them dry and reassembled. I used epoxy this time; at the tubing joint, on the whole front edge (in the indent), and on most of the back side. Once the epoxy set up they do not move
Over all I notice a smaller side wake (when it rains no wide plume of mist). As for mods it is a very simple 1MPG gain!
Old 09-19-2010, 11:05 PM   #56 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Weather Spotter -
That's been in the back of my mind too. I have a pizza pan project that doesn't make any sound, but it does leave a gap. I keep thinking that if I do a tube gasket to seal it, the tube will eventually come off. After all, it's constanty being "pulled" out by the spinning. I may just leave the gap and call it a "brake heat vent", .
CarloSW2
Old 09-20-2010, 09:23 AM   #57 (permalink)
Wiki Mod
the tube stayed on without any glue for 150+ miles. I was planning a trip so did a quick hot glue job which helped. I also used the pizza pan to hold the tube snug to the rim. it only seemed to want to come off during breaking or speeding up while going over bumps.
Old 09-20-2010, 11:22 AM   #58 (permalink)
...beats walking...
WX_Spotter -- what do you do about the valve-stems and checking air-pressure?
...those of us with the Tire Pressure (warning) System (TPS) have metal valve-stems which make checking air-pressure a PITA.
Old 09-20-2010, 11:45 AM   #59 (permalink)
Wiki Mod
I have thought about making a hole in the pan to access the valve stem, not sure I want to do that. For now I just take the pans off to check tire pressure. This makes it a hassle to check -so I do it less (still about every 3 weeks). My car is one year older than TPS systems so I have the plastic valve stem
What are your ideas for a 1 to 1.5" hole for valve stem access?
Looks?
degradation of function?
will a hole mess up the balance of the wheel?
Old 09-20-2010, 11:58 AM   #60 (permalink)
Gen II Prianista
Rokeby's Avatar
Cleanest way to cut the holes would be to punch them w/one of these, ~$25USD:
from here.
Sort of like a heavy duty paper punch. You drill a small hole, ~1/4 in. dia.
One piece of the punch goes on either side of the panel.
Then draw the two pieces of the punch together on the threaded shaft.
Bingo! Very clean hole that needs little/no clean-up.
The Following 2 Users Say Thank You to Rokeby For This Useful Post:
cfg83 (09-20-2010), Weather Spotter (09-20-2010)
Commercial Aero Race Wheel covers (clear acrylic) cfg83 Aerodynamics 8 09-20-2010 11:09 PM
aero caps and wheel balancing lightning Aerodynamics 3 05-01-2009 06:54 PM
check out my taped hub caps! modmonster Aerodynamics 9 01-17-2009 10:45 PM
"Pizza pan" hub caps (2008 Civic)? KJSatz Aerodynamics 2 08-05-2008 12:14 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
